L2TP/IPSec connection with limited access
Hi All
I want to give someone access into a network via VPN but only want to give them access to 2 or 3 IPs in the range.
How can this be accomplished?
Thanks,
R
Figured out a rudimentary solutions … set an address list with the addresses I want to be accessible. Then created a firewall rule in which I stated all forwarded info from an IP range (specified the VPN connections range) to Dst Address List NOT “the list I created” must be dropped.
Sure there must be a prettier way but this works and it’s only a temp thing anyway :wink:
