L2TP/IPSec crashes RB4011
I have a L2TP/IPSec setup with my RB4011 and an Android 11 device. When my phone was using Android 10, I could connect to the VPN and do whatever I needed. However, with the new update, it crashes whenever I push some “real data” through. This means that speedtests result in a reboot, even if the phone’s LTE connection is a paltry 6 Mbps. SSH and Winbox are about all I can do, but that’s better than nothing. Is there a fix?
Just to confirm: on a “loadtest” using VPN your RB4011 reboots?
Perhaps you can share your configuration to have a better understanding of your environment?
/export hide-sensitive file=anythingyoulike
It reboots on a load test, and here's my whole configuration.
RB4011.rsc (23.3 KB)
You might better post this in the version specific topic:
http://forum.mikrotik.com/t/v7-1beta6-development-is-released/149195/1
I already did, but this forum section is also specifically to report issues with v7.
Sorry, I always use “ACTIVE TOPICS”, hence the misunderstanding. Hope support can help you, have you already created a support file?
https://wiki.mikrotik.com/wiki/Manual:Support_Output_File
