Hello, ok so every time i’m connecting with l2tp+ipsec encryption is allways MPPE128 stateless and i don’t get it why is this happening.. my config is like this:
IPSEC
/ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - inactive, * - default
0 T * group=default src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
/ip ipsec peer print
Flags: X - disabled, D - dynamic
0 address=0.0.0.0/0 local-address=0.0.0.0 passive=yes port=500 auth-method=pre-shared-key secret="mypass"
generate-policy=port-override policy-template-group=default exchange-mode=main-l2tp send-initial-contact=yes
nat-traversal=yes hash-algorithm=sha1 enc-algorithm=3des,aes-128,aes-192,aes-256 dh-group=modp1024
lifetime=1d dpd-interval=2m dpd-maximum-failures=5
/ip ipsec proposal print
Flags: X - disabled, * - default
0 * name="default" auth-algorithms=sha1 enc-algorithms=3des,aes-128-cbc,aes-192-cbc,aes-256-cbc lifetime=30m
pfs-group=modp1024
/ip ipsec user print
# NAME PASSWORD ADDRESS
0 ipsec_user mypass
and L2TP
/interface l2tp-server server print
enabled: yes
max-mtu: 1450
max-mru: 1450
mrru: disabled
authentication: pap,chap,mschap1,mschap2
keepalive-timeout: 30
default-profile: l2tp_ipsec
use-ipsec: yes
ipsec-secret: mypass
/interface l2tp-server print
Flags: X - disabled, D - dynamic, R - running
# NAME USER MTU CLIENT-ADDRESS UPTIME ENCODING
0 DR <l2tp-ipsec_user> ipsec_user 1400 193.x.x.x 1m50s MPPE128 stateless
/ppp profile print
Flags: * - default
5 name="l2tp_ipsec" local-address=192.168.30.1 remote-address=vpn_pool use-mpls=default use-compression=default use-encryption=required
only-one=default change-tcp-mss=yes use-upnp=yes address-list="" dns-server=8.8.8.8,8.8.4.4 on-up="" on-down=""
/ppp secret print
Flags: X - disabled
# NAME SERVICE CALLER-ID PASSWORD PROFILE REMOTE-ADDRESS
4 ipsec_user l2tp mypass vpn_all
Is there something wrong in my config?
