Hello.
I have two problems with L2TP/IPsec for RoadWarrior configuration:
- I am unable to change keepalive-timeout on L2TP server. I can set it to 30 or 36000 or even disable but MT starts to send L2TP HELLO packets exactly 60 seconds after connection established.
- That is weird. When some traffic is present through the L2TP tunnel (pings or shared files access) HELLO packets are sent and received normally. But when the tunnel is idle keepalive packets seems to be ignored by one of the sides.
L2TP client is Win10 machine.
RouterOS 6.37.3
Export and L2TP log below
set [ find default-name=ether2 ] arp=proxy-arp
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc,3des
add name=VPN_pool ranges=192.168.4.50-192.168.4.100
/ppp profile
add change-tcp-mss=yes local-address=192.168.3.252 name=VPN_profile remote-address=VPN_pool
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=VPN_profile enabled=yes
add address=192.168.3.252/24 comment=Inside interface=ether2 network=192.168.3.0
add address=10.1.1.1/24 comment=Outside interface=ether6 network=10.1.1.0
set servers=192.168.3.1
add action=masquerade chain=srcnat out-interface=ether6
/ip ipsec peer
add address=0.0.0.0/0 exchange-mode=main-l2tp generate-policy=port-override secret=test
add distance=1 gateway=10.1.1.254
/ppp secret
add name=vpn_user password=test profile=VPN_profile service=l2tp
20:28:30 l2tp,debug,packet rcvd control message from 10.1.1.2:1701 to 10.1.1.1:1701
20:28:30 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
20:28:30 l2tp,debug,packet (M) Message-Type=SCCRQ
20:28:30 l2tp,debug,packet (M) Protocol-Version=0x01:00
20:28:30 l2tp,debug,packet (M) Framing-Capabilities=0x1
20:28:30 l2tp,debug,packet (M) Bearer-Capabilities=0x0
20:28:30 l2tp,debug,packet Firmware-Revision=0xa00
20:28:30 l2tp,debug,packet (M) Host-Name="laptop.testdomain.local"
20:28:30 l2tp,debug,packet Vendor-Name="Microsoft"
20:28:30 l2tp,debug,packet (M) Assigned-Tunnel-ID=36
20:28:30 l2tp,debug,packet (M) Receive-Window-Size=8
20:28:30 l2tp,info first L2TP UDP packet received from 10.1.1.2
20:28:30 l2tp,debug tunnel 9 entering state: wait-ctl-conn
20:28:30 l2tp,debug,packet sent control message to 10.1.1.2:1701 from 10.1.1.1:1701
20:28:30 l2tp,debug,packet tunnel-id=36, session-id=0, ns=0, nr=1
20:28:30 l2tp,debug,packet (M) Message-Type=SCCRP
20:28:30 l2tp,debug,packet Firmware-Revision=0x1
20:28:30 l2tp,debug,packet (M) Host-Name="MikroTik"
20:28:30 l2tp,debug,packet Vendor-Name="MikroTik"
20:28:30 l2tp,debug,packet (M) Assigned-Tunnel-ID=9
20:28:30 l2tp,debug,packet (M) Receive-Window-Size=4
20:28:30 l2tp,debug,packet tunnel-id=9, session-id=0, ns=1, nr=1
20:28:30 l2tp,debug,packet (M) Message-Type=SCCCN
20:28:30 l2tp,debug tunnel 9 entering state: estabilished
20:28:30 l2tp,debug,packet sent control message (ack) to 10.1.1.2:1701 from 10.1.1.1:1701
20:28:30 l2tp,debug,packet tunnel-id=36, session-id=0, ns=1, nr=2
20:28:30 l2tp,debug,packet rcvd control message (ack) from 10.1.1.2:1701 to 10.1.1.1:1701
20:28:30 l2tp,debug,packet tunnel-id=9, session-id=0, ns=3, nr=1
20:28:30 l2tp,debug,packet tunnel-id=9, session-id=0, ns=2, nr=1
20:28:30 l2tp,debug,packet (M) Message-Type=ICRQ
20:28:30 l2tp,debug,packet (M) Assigned-Session-ID=1
20:28:30 l2tp,debug,packet (M) Call-Serial-Number=0
20:28:30 l2tp,debug,packet (M) Bearer-Type=0x2
20:28:30 l2tp,debug,packet 1(vendor-id=311)=0x26:b5:ab:86:57:06:e5:47:9b:6d:a9:bf:90:9b:12:06
20:28:30 l2tp,debug session 1 entering state: wait-connect
20:28:30 l2tp,debug,packet tunnel-id=36, session-id=1, ns=1, nr=3
20:28:30 l2tp,debug,packet (M) Message-Type=ICRP
20:28:30 l2tp,debug,packet tunnel-id=9, session-id=1, ns=3, nr=2
20:28:30 l2tp,debug,packet (M) Message-Type=ICCN
20:28:30 l2tp,debug,packet (M) Tx-Connect-Speed-BPS=54000000
20:28:30 l2tp,debug,packet (M) Framing-Type=0x1
20:28:30 l2tp,debug,packet Proxy-Authen-Type=4
20:28:30 l2tp,debug session 1 entering state: established
20:28:30 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=4
20:28:30 l2tp,debug,packet tunnel-id=9, session-id=0, ns=4, nr=2
20:28:30 l2tp,ppp,debug <10.1.1.2>: LCP lowerup
20:28:30 l2tp,ppp,debug <10.1.1.2>: LCP open
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd LCP ConfReq id=0x0
20:28:30 l2tp,ppp,debug,packet <mru 1400>
20:28:30 l2tp,ppp,debug,packet <magic 0x129c5825>
20:28:30 l2tp,ppp,debug,packet <pcomp>
20:28:30 l2tp,ppp,debug,packet <accomp>
20:28:30 l2tp,ppp,debug,packet <callback 0x06>
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent LCP ConfReq id=0x1
20:28:30 l2tp,ppp,debug,packet <mru 1450>
20:28:30 l2tp,ppp,debug,packet <magic 0x49f46e4c>
20:28:30 l2tp,ppp,debug,packet <auth mschap2>
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent LCP ConfRej id=0x0
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd LCP ConfAck id=0x1
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd LCP ConfReq id=0x1
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent LCP ConfAck id=0x1
20:28:30 l2tp,ppp,debug <10.1.1.2>: LCP opened
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent CHAP Challenge id=0x1
20:28:30 l2tp,ppp,debug,packet <challenge len=16>
20:28:30 l2tp,ppp,debug,packet <name MikroTik>
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd LCP Ident id=0x2
20:28:30 l2tp,ppp,debug,packet MSRASV5.20
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd LCP Ident id=0x3
20:28:30 l2tp,ppp,debug,packet MSRAS-0-R9-F20M0
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd LCP Ident id=0x4
20:28:30 l2tp,ppp,debug,packet &\B5\AB\86W\06\E5G\9Bm\A9\BF\90\9B\12\06
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd CHAP Response id=0x1
20:28:30 l2tp,ppp,debug,packet <response len=49>
20:28:30 l2tp,ppp,debug,packet <name vpn_user>
20:28:30 l2tp,ppp,info,account vpn_user logged in, 192.168.4.98
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent CHAP Success id=0x1
20:28:30 l2tp,ppp,debug,packet S=447E540B0BA08BE331DE8024E7B30DCE790A80D7
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent CBCP CallbackReq id=0x0
20:28:30 l2tp,ppp,debug,packet 01 02
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd CBCP CallbackResp id=0x0
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent CBCP CallbackAck id=0x1
20:28:30 l2tp,ppp,info <l2tp-vpn_user>: authenticated
20:28:30 l2tp,ppp,debug <10.1.1.2>: IPCP lowerup
20:28:30 l2tp,ppp,debug <10.1.1.2>: IPCP open
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent IPCP ConfReq id=0x1
20:28:30 l2tp,ppp,debug,packet <addr 192.168.3.252>
20:28:30 l2tp,ppp,debug <10.1.1.2>: IPV6CP open
20:28:30 l2tp,ppp,debug <10.1.1.2>: MPLSCP lowerup
20:28:30 l2tp,ppp,debug <10.1.1.2>: MPLSCP open
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent MPLSCP ConfReq id=0x1
20:28:30 l2tp,ppp,debug <10.1.1.2>: BCP open
20:28:30 l2tp,ppp,debug <10.1.1.2>: CCP lowerup
20:28:30 l2tp,ppp,debug <10.1.1.2>: CCP open
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd CCP ConfReq id=0x5
20:28:30 l2tp,ppp,debug,packet <mppe 1000000>
20:28:30 l2tp,ppp,debug <10.1.1.2>: received unsupported protocol 0x80fd
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent LCP ProtRej id=0x2
20:28:30 l2tp,ppp,debug,packet 80 fd 01 05 00 0a 12 06 01 00 00 00
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd IPCP ConfReq id=0x6
20:28:30 l2tp,ppp,debug,packet <addr 0.0.0.0>
20:28:30 l2tp,ppp,debug,packet <ms-dns 0.0.0.0>
20:28:30 l2tp,ppp,debug,packet <ms-wins 0.0.0.0>
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent IPCP ConfRej id=0x6
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd LCP ProtRej id=0x7
20:28:30 l2tp,ppp,debug,packet 82 81 01 01 00 04
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd IPCP ConfAck id=0x1
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd IPCP ConfReq id=0x8
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent IPCP ConfNak id=0x8
20:28:30 l2tp,ppp,debug,packet <addr 192.168.4.98>
20:28:30 l2tp,ppp,debug,packet <ms-dns 192.168.3.1>
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: rcvd IPCP ConfReq id=0x9
20:28:30 l2tp,ppp,debug,packet <10.1.1.2>: sent IPCP ConfAck id=0x9
20:28:30 l2tp,ppp,debug <10.1.1.2>: IPCP opened
20:28:30 l2tp,ppp,info <l2tp-vpn_user>: connected
20:29:20 l2tp,debug,packet rcvd control message from 10.1.1.2:1701 to 10.1.1.1:1701
20:29:20 l2tp,debug,packet tunnel-id=9, session-id=0, ns=4, nr=2
20:29:20 l2tp,debug,packet (M) Message-Type=HELLO
20:29:20 l2tp,debug,packet sent control message (ack) to 10.1.1.2:1701 from 10.1.1.1:1701
20:29:20 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=5
20:29:30 l2tp,debug,packet rcvd control message from 10.1.1.2:1701 to 10.1.1.1:1701
20:29:30 l2tp,debug,packet tunnel-id=9, session-id=0, ns=4, nr=2
20:29:30 l2tp,debug,packet (M) Message-Type=HELLO
20:29:30 l2tp,debug,packet sent control message (ack) to 10.1.1.2:1701 from 10.1.1.1:1701
20:29:30 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=5
20:29:30 l2tp,debug,packet sent control message to 10.1.1.2:1701 fr
20:29:31 l2tp,debug,packet sent control message to 10.1.1.2:1701 fr
20:29:31 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=5
20:29:31 l2tp,debug,packet (M) Message-Type=HELLO
20:29:32 l2tp,debug,packet sent control message to 10.1.1.2:1701 fr
20:29:32 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=5
20:29:32 l2tp,debug,packet (M) Message-Type=HELLO
20:29:34 l2tp,debug,packet sent control message to 10.1.1.2:1701 fr
20:29:34 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=5
20:29:34 l2tp,debug,packet (M) Message-Type=HELLO
20:29:38 l2tp,debug,packet sent control message to 10.1.1.2:1701 fr
20:29:38 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=5
20:29:38 l2tp,debug,packet (M) Message-Type=HELLO
20:29:40 l2tp,debug,packet rcvd control message from 10.1.1.2:1701
20:29:40 l2tp,debug,packet tunnel-id=9, session-id=0, ns=4, nr=2
20:29:40 l2tp,debug,packet (M) Message-Type=HELLO
20:29:40 l2tp,debug,packet sent control message (ack) to 10.1.1.2:1
20:29:40 l2tp,debug,packet tunnel-id=36, session-id=0, ns=3, nr=5
20:29:46 l2tp,debug,packet sent control message to 10.1.1.2:1701 fr
20:29:46 l2tp,debug,packet tunnel-id=36, session-id=0, ns=2, nr=5
20:29:46 l2tp,debug,packet (M) Message-Type=HELLO
20:29:50 l2tp,debug,packet rcvd control message from 10.1.1.2:1701
20:29:50 l2tp,debug,packet tunnel-id=9, session-id=0, ns=4, nr=2
20:29:50 l2tp,debug,packet (M) Message-Type=HELLO
20:29:50 l2tp,debug,packet sent control message (ack) to 10.1.1.2:1
20:29:50 l2tp,debug,packet tunnel-id=36, session-id=0, ns=3, nr=5
20:29:50 l2tp,debug tunnel 9 received no replies, disconnecting
20:29:50 l2tp,debug tunnel 9 entering state: dead
20:29:50 l2tp,debug session 1 entering state: dead
20:29:50 l2tp,ppp,debug <10.1.1.2>: LCP lowerdown
20:29:50 l2tp,ppp,debug <10.1.1.2>: LCP closed
20:29:50 l2tp,ppp,debug <10.1.1.2>: CCP lowerdown
20:29:50 l2tp,ppp,debug <10.1.1.2>: BCP lowerdown
20:29:50 l2tp,ppp,debug <10.1.1.2>: BCP down event in starting stat
20:29:50 l2tp,ppp,debug <10.1.1.2>: IPCP lowerdown
20:29:50 l2tp,ppp,debug <10.1.1.2>: IPCP closed
20:29:50 l2tp,ppp,debug <10.1.1.2>: IPV6CP lowerdown
20:29:50 l2tp,ppp,debug <10.1.1.2>: IPV6CP down event in starting s
20:29:50 l2tp,ppp,debug <10.1.1.2>: MPLSCP lowerdown
20:29:50 l2tp,ppp,info <l2tp-vpn_user>: terminating... - hungup
20:29:50 l2tp,ppp,debug <10.1.1.2>: LCP down event in starting stat
20:29:50 l2tp,ppp,info,account vpn_user logged out, 80 11326 68 146 5
20:29:50 l2tp,ppp,info <l2tp-vpn_user>: disconnected
20:30:00 l2tp,debug,packet rcvd control message from 10.1.1.2:1701
20:30:00 l2tp,debug,packet tunnel-id=9, session-id=0, ns=4, nr=2
20:30:00 l2tp,debug,packet (M) Message-Type=HELLO
20:30:10 l2tp,debug,packet rcvd control message from 10.1.1.2:1701
20:30:10 l2tp,debug,packet tunnel-id=9, session-id=0, ns=4, nr=2
20:30:10 l2tp,debug,packet (M) Message-Type=HELLO
