Hi.
I am not a newbie to mikrotik, but i am stuck for days with this. I hope someone will help me with this.
I have set up central hq vpn server for remote management and file access. Everything is ok, people can connect to it, but after connection is established nothing works. Pinging is returning “General failure”, cannot access vpn server… nothing
On the other hand, when i connect from my iPhone, i can access everything from phone.
We have 3 branches. On each remote site there is mikrotik connected to HQ through l2tp/ipsec for access to local resources. Problem is only with road warriors
HQ server gives 10.0.1.0/24 adressess for local clients.
10.0.3.0/24 gives to vpn clients(branches and road warriors)
Here is export:
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
frequency=2437 frequency-mode=superchannel ht-basic-mcs="mcs-0,mcs-1,mcs-2,m\
cs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,\
mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" mode=\
ap-bridge ssid="Office - 2.4G" wireless-protocol=802.11 wmm-support=enabled \
wps-mode=disabled
add admin-mac=64:D1:54:EE:DE:8A arp=proxy-arp auto-mac=no fast-forward=no \
igmp-snooping=yes name=bridge
set [ find default-name=ether1 ] arp=proxy-arp mac-address=98:DE:D0:5C:0E:85
set [ find default-name=ether2 ] rx-flow-control=auto tx-flow-control=auto
/interface l2tp-server
add name=aleksa user=aleksa
add name=aleksa.sn user=aleksa.sn
add name=jav.beleznik user=jav.beleznik
add name=posejdon.galerija user=posejdon.galerija
add name=posejdon.r user=posejdon.r
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wireless channels
add band=2ghz-b/g/n extension-channel=Ce frequency=2443 list=1 name=ch1 width=\
20
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" \
group-ciphers=tkip,aes-ccm management-protection=allowed mode=dynamic-keys \
supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
/ip hotspot profile
set [ find default=yes ] hotspot-address=10.0.1.2 login-by=http-chap
add name=default-dhcp ranges=10.0.1.50-10.0.1.254
add name=pool1 ranges=10.0.3.2-10.0.3.50
add add-arp=yes address-pool=default-dhcp disabled=no interface=bridge \
lease-time=1d name=dhcp
add add-arp=yes address-pool=pool1 disabled=no interface=ether3 lease-time=\
1d10m name=server1
/ppp profile
set *0 use-encryption=yes
add change-tcp-mss=yes dns-server=1.1.1.1,1.0.0.1 local-address=default-dhcp \
name=l2tp use-encryption=yes
add change-tcp-mss=yes dns-server=1.1.1.1,1.0.0.1 local-address=10.0.1.1 name=\
profile1 remote-address=pool1 use-encryption=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=fiber-wan profile=\
default-encryption user=aleksa.sn
/queue type
add kind=pcq name=pcq-down pcq-burst-time=3s pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-src-address6-mask=64
add kind=pcq name=pcq-up pcq-burst-time=3s pcq-classifier=src-address \
pcq-dst-address6-mask=64 pcq-limit=70KiB pcq-src-address6-mask=64
set 7 pcq-burst-time=3s
set 8 pcq-burst-time=3s
/queue simple
add bucket-size=0.5/0.5 disabled=yes name=queue1 queue=pcq-up/pcq-down target=\
10.0.1.0/24
/queue tree
add disabled=yes name=total-traffic parent=global priority=2 queue=\
synchronous-default
add max-limit=12M name=upload packet-mark=client_upload parent=global priority=\
4 queue=pcq-up
add max-limit=100M name=download packet-mark=client_download parent=global \
priority=4 queue=pcq-down
/snmp community
set [ find default=yes ] encryption-protocol=AES security=authorized
add bridge=bridge interface=ether2
add bridge=bridge disabled=yes interface=wlan1
add bridge=bridge interface=ether4
/interface bridge settings
set use-ip-firewall=yes
set discover-interface-list=all
/interface l2tp-server server
set allow-fast-path=yes authentication=chap,mschap2 default-profile=profile1 \
enabled=yes max-mru=1500 max-mtu=1480 use-ipsec=required
add interface=bridge list=LAN
add interface=fiber-wan list=WAN
add interface=ether3 list=LAN
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=profile1 enabled=\
yes
/interface wireless align
set receive-all=yes ssid-all=yes
add address=10.0.1.1/24 interface=bridge network=10.0.1.0
add address=192.168.1.200 interface=ether1 network=192.168.1.0
add address=212.69.31.239 disabled=yes interface=fiber-wan network=\
185.157.44.194
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=10.0.1.10 always-broadcast=yes client-id=1:0:21:85:c7:fd:8c \
mac-address=00:21:85:C7:FD:8C server=dhcp
add address=10.0.1.250 client-id=1:98:de:d0:3c:e:89 mac-address=\
98:DE:D0:3C:0E:89 server=dhcp
add address=10.0.1.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.0.1.1
add address=10.0.3.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.0.3.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=10.0.1.1 name=router.lan
add address=10.0.5.1 name=posejdon-r.lan
add address=10.0.15.1 name=p-galerija.lan
add address=10.0.10.1 name=beleznik.lan
/ip firewall address-list
add address=10.0.1.0/24 list=client_subnets
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
disabled=yes
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input dst-port=500 in-interface-list=WAN protocol=udp
add action=accept chain=input disabled=yes dst-port=161 in-interface=fiber-wan \
protocol=udp
add action=accept chain=input dst-port=4500 in-interface-list=WAN protocol=udp
add action=accept chain=input dst-port=1701 in-interface-list=WAN protocol=udp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
add action=accept chain=input protocol=gre
established,related,untracked
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes
invalid
add action=drop chain=input comment="drop all coming from WAN" \
in-interface-list=WAN log=yes log-prefix="fw drop"
/ip firewall mangle
add action=mark-packet chain=forward new-packet-mark=client_upload \
out-interface=fiber-wan passthrough=yes src-address-list=client_subnets
add action=mark-packet chain=forward dst-address-list=client_subnets \
in-interface=fiber-wan new-packet-mark=client_download passthrough=yes
disabled=yes
add action=accept chain=srcnat src-address=10.0.3.0/24
add action=accept chain=srcnat disabled=yes dst-address=0.0.0.0/0 ipsec-policy=\
out,none src-address=10.0.3.0/24
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=\
fiber-wan
/ip ipsec peer
add address=0.0.0.0/0 compatibility-options=skip-peer-id-validation \
enc-algorithm=aes-256,aes-192,aes-128,3des exchange-mode=main-l2tp \
generate-policy=port-override
/ip proxy
set max-cache-size=none
add distance=1 dst-address=10.0.0.0/24 gateway=bridge
add distance=1 dst-address=10.0.3.0/24 gateway=bridge
add distance=2 dst-address=10.0.5.0/24 gateway=10.0.1.21
add distance=2 dst-address=10.0.10.0/24 gateway=10.0.3.101
add distance=2 dst-address=10.0.15.0/24 gateway=10.0.3.115
add distance=2 dst-address=10.0.16.0/24 gateway=posejdon.galerija
add distance=2 dst-address=192.168.2.0/24 gateway=posejdon.galerija
/ip service
set ftp disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
/ppp secret
add name=aleksa.sn profile=l2tp remote-address=10.0.3.99 routes=\
"10.0.0.0/16 10.0.3.0/24 10.0.5.0/24 10.0.10.0/24"
add name=aleksa profile=profile1
add local-address=10.0.1.1 name=jav.beleznik profile=default-encryption \
remote-address=10.0.3.101
add local-address=10.0.1.20 name=posejdon.r profile=default-encryption \
remote-address=10.0.3.102
add name=posejdon.galerija profile=l2tp remote-address=10.0.3.115 routes=\
"10.0.0.0/16 10.0.3.0/24 10.0.5.0/24 10.0.10.0/24 10.0.15.0/24"
/snmp
set contact=public enabled=yes trap-generators=start-trap trap-interfaces=all \
trap-target=0.0.0.0 trap-version=3
/system clock
set time-zone-name=Europe/Belgrade
/system identity
set name="hAP Aleksa"
/system leds
add interface=fiber-wan leds=user-led type=interface-activity
/system ntp client
set enabled=yes primary-ntp=94.127.6.166
/system routerboard settings
set auto-upgrade=yes cpu-frequency=750MHz silent-boot=no
/system script
add name=wol owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
"tool wol interface=ether2 mac=00:21:85:C7:FD:8C"
/system watchdog
set watchdog-timer=no
/tool bandwidth-server
set authenticate=no enabled=no max-sessions=1
/tool mac-server
/tool mac-server mac-winbox
