Hello all,
I don’t know if this post is duplicated and apologies for this. I have created my LT2P/IPSEC site to site VPN but I am having some problem. I have attached the topology.
Both mikrotik router are behind the NAT (ISP modem). Both ISP modem cannot be moved in bridge. The VPN is up and stable. I have created the route pointing the L2TP gateway, the mangle on the L2TP client to mark the traffic and route to the correct gateway. from both pc I am able to ping the LAN gateway, but not able to ping each other. from the client side I traced google and I see the traffic is correctly going thru the tunnel, but if I open a webpage I can’t navigate.
To be able to connect to an L2TP IPSec server behind NAT, you need to open:
To allow Internet Key Exchange (IKE), open UDP 500.
To allow IPSec Network Address Translation (NAT-T) open UDP 5500.
To allow L2TP traffic, open UDP 1701.
Yes, IPsec L2TP tunnel is up and stable. From the host on 192.168.88.0/24 I am able to ping the gateway of the host 192.168.99.0.24 and viceversa.
first problem I cannot ping host to host.Traceroute from host is stopping to the tunnel IP ( I tested from both side)
second problem, I want to reach internet from the host 192.168.99.0/24 through the tunnel, so the public IP should be 1.1.1.1. I cannot open any internet pages but if I try to ping 8.8.8.8 is responding, plus if I trace it I see that the traffic is correctly going through the tunnel.
I am currently thinking to some asymmetric routing but I spent the last three days and I cannot figure out what is going on.
All ports are open on both ISP modem (1710 50 51 4500) plus I add the Mikrotik IP to the ISP DMZ
Thank you DeJoe, I will try as you suggested. The reason why I used as next-hop the IP instead of the tunnel interface is because if the VPN will flap for some reason the router will flushed out the route from his routing table. But for sure I will try and I will let you know.
I tried to use the tunnel interface as next-hop (as DeJoe suggested) however is the same.
The L2TP server seems to be fine. I tested with a spare Windows laptop connected via LTE and I was able to establish the VPN and the traffic was passing through the tunnel. I received the public IP address of the server on my windows laptop. All fine. This test was aside from the Mikrotik client router.
But again everything connected to the Mikrotik client can’t navigate even if the L2TP tunnel is up. If I trace Google or another website from the Mikrotik client sourcing the subnet 192.168.99.0/24 I see the traffic going correctly thru the tunnel… meaning also the mangle rule is working.
Can you ping 192.168.99.1 from 192.168.88.1 ?
Can you ping 192.168.88.1 from a client in 192.168.99.0/24 ?
Can you ping 192.168.99.1 from a client in 192.168.88.0/24 ?
So guys after several days and attempts on this I found finally the problem. Nothing wrong on the configuration of both Mikrotik. The problem is on the ISP of the Mikrotik client. The ISP is using a WiMAX technology. The ISP modem on the picture with the IP 192.168.0.1 is connected to the ISP antenna…so basically the Mikrotik is behind 2 NAT (ISP modem and ISP antenna). What basically I did to discover that the problem is with the ISP ? I turned on hotspot WiFi in my phone and I bind with the Mikrotik client so basically I used my phone as gateway. The L2TP IPsec was successful established and I wa able to navigate and the traffic was going thru the tunnel as per design. So I suspect some problem with the returning traffic or asymmetric traffic.
Thanks all
In my experience, to make double-NAT (and other obscure NAT situations) working you need to relax the checking of port numbers in IPsec.
Assuming that you have made the L2TP server with default IPsec settings, note down what entries it has created under IP->IPsec for that, then remove the IPsec from the L2TP server and re-create these entries manually.
However, on the Identities tab, in this entry select “port override” instead of the “port strict” that was there when the entry is auto-created.
That usually solves it.
Make sure your firewall accepts UDP port 1701 incoming traffic (on the MikroTik) only with IPsec policy in:ipsec (on the Advanced tab).
Well pe1chl, the IPsec was established and the UDPs ports were opens. No issues with the server, only in the client side. So traffic was passing through the tunnel but I was able to ping and trace Google from the hosts behind the L2TP client but I wasn’t able to navigate with all browsers. So definitely no issues with the ports.
If the tunnel is up and working, the ports are ok and double NAT has nothing to do with it. If pinging route to router works but the clients are not reachable from site to site, the problem is most likely related to a routing problem or firewall.
If you can, you could post your complete config. Hide the sensitive values, please. Maybe we find the issue.
Hey DeJoe thanks for your reply. The config is already in the post above. When I say NAT, I am not speaking only about the ports but the ability to translate the private ip address to a public one …so I think the problem could be on the provider network. When I do the normal traceroute to Google I see the first hop is my gateway 192.168.0.1 second hop is the private ip of my antenna ISP and third hop is a IP my pubblic IP address.
