L2TP + IPSEC - stupid problem
Hello friends,
I have some problem with routerboard 1200 ROS 5.7.
I need make configuration L2TP + IPSEC
My current configuration is :
/interface l2tp-server server print
enabled: yes
max-mtu: 1460
max-mru: 1460
mrru: disabled
authentication: mschap2
default-profile: default-encryption
/ip ipsec proposal print
Flags: X - disabled
0 name=“proposal1” auth-algorithms=sha1 enc-algorithms=aes-128 lifetime=30m pfs-group=modp1024
/ip ipsec peer print
0 address=192.168.0.5/32 port=500 auth-method=pre-shared-key secret=“test” generate-policy=yes exchange-mode=main
send-initial-contact=no nat-traversal=yes my-id-user-fqdn=“” proposal-check=obey hash-algorithm=sha1
enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=disable-dpd dpd-maximum-failures=1
but i receive one stupid error :
19:04:17 ipsec,debug,packet ==========
19:04:17 ipsec,debug,packet 68 bytes message received from xx.xx.xx.xx[31091] to xx.xx.xx.xx[4500]
19:04:17 ipsec,debug,packet c3194dca 6e35bbee fabafead 7af830e8 05100201 00000000 00000044 639c1291
19:04:17 ipsec,debug,packet 305e690c ede50622 1968cdca b723e518 ff35f794 3f8d39c0 9fe1ea0b cdcc8a7e
19:04:17 ipsec,debug,packet b78cbd12
19:04:17 ipsec,debug,packet encryption(3des)
19:04:17 ipsec,debug,packet IV was saved for next processing:
19:04:17 ipsec,debug,packet cdcc8a7e b78cbd12
19:04:17 ipsec,debug,packet with key:
19:04:17 ipsec,debug,packet 3c7e22b4 3c7e22b4 3c7e22b4 4727fcc9 3c7e22b4 3c7e22b4
19:04:17 ipsec,debug,packet decrypted payload by IV:
19:04:17 ipsec,debug,packet decrypted payload, but not trimed.
19:04:17 ipsec,debug,packet 3c7e22b4 3c7e22b4 3c7e22b4 3c7e22b4 3c7e22b4 3c7e22b4 3c7e22b4 3c7e22b4
19:04:17 ipsec,debug,packet 3a2b0611 79ac1abf
19:04:17 ipsec,debug,packet padding len=192
19:04:17 ipsec,debug,packet skip to trim padding.
19:04:17 ipsec,debug,packet decrypted.
19:04:17 ipsec,debug,packet 3c7e22b4 3c7e22b4 fabafead 3c7e22b4 05100201 00000000 00000044 ebdd592a
19:04:17 ipsec,debug,packet e8656618 cfb73969 9579a4c3 3c7e22b4 3c7e22b4 3c7e22b4 053f14db 3a2b0611
19:04:17 ipsec,debug,packet 79ac1abf
19:04:17 ipsec,debug,packet begin.
19:04:17 ipsec,debug,packet seen nptype=5(id)
19:04:17 ipsec,debug invalid length of payload
19:04:23 ipsec,debug,packet ==========
Anybody help me ?
Thanks advance!
Any ideas ?
