L2TP/IPSec to OSX Client Failing at IPSec
So I am trying to setup L2TP/IPSec for OSX clients. It is failing at the IPSec Phase 1 (I think). I have included my config below. The other two peer configurations work just fine. It is only the L2TP/IPSec Peer/Proposal/etc that is having a problem. Thoughts?
/ip ipsec peer
add comment=“L2TP/IPsec Road Warrior” exchange-mode=main-l2tp generate-policy=port-override hash-algorithm=sha1 nat-traversal=yes policy-group=l2tp-group secret=“”
add auth-method=pre-shared-key-xauth comment=“IPSec Road Warrior” exchange-mode=aggressive generate-policy=port-override mode-cfg=roadwarrior-config nat-traversal=yes passive=yes policy-group=
ipsec-group secret=“” send-initial-contact=no
add address=STATIC auth-method=rsa-key dpd-interval=disable-dpd dpd-maximum-failures=1 key=key2 remote-key=key2 send-initial-contact=no
/ip ipsec policy group
add name=ipsec-group
add name=l2tp-group
/ip ipsec policy
add comment=“IPSec Road Warrior” dst-address=10.0.1.0/24 group=ipsec-group proposal=roadwarrior src-address=10.0.11.0/24 template=yes
add comment=“L2TP/IPSec Road Warrior” group=l2tp-group proposal=l2tp template=yes
add dst-address=STATIC proposal=sitetosite protocol=47 sa-dst-address=STATIC sa-src-address=STATIC src-address=STATIC/32
/ip ipsec proposal
add enc-algorithms=3des,aes-256,twofish name=l2tp pfs-group=none
add auth-algorithms=md5 name=roadwarrior
add name=sitetosite
IPSEC DEBUG
11:16:28 ipsec,debug,packet ==========
11:16:28 ipsec,debug,packet 500 bytes message received from 70.215.46.81[13086] to 96.231.138.100[500]
11:16:28 ipsec,debug,packet c902be40 96890b36 00000000 00000000 01100200 00000000 000001f4 0d0000e4
11:16:28 ipsec,debug,packet 00000001 00000001 000000d8 01010006 03000024 01010000 800b0001 800c0e10
11:16:28 ipsec,debug,packet 80010007 800e0100 80030001 80020002 80040002 03000024 02010000 800b0001
11:16:28 ipsec,debug,packet 800c0e10 80010007 800e0100 80030001 80020001 80040002 03000024 03010000
11:16:28 ipsec,debug,packet 800b0001 800c0e10 80010007 800e0080 80030001 80020002 80040002 03000024
11:16:28 ipsec,debug,packet 04010000 800b0001 800c0e10 80010007 800e0080 80030001 80020001 80040002
11:16:28 ipsec,debug,packet 03000020 05010000 800b0001 800c0e10 80010005 80030001 80020002 80040002
11:16:28 ipsec,debug,packet 00000020 06010000 800b0001 800c0e10 80010005 80030001 80020001 80040002
11:16:28 ipsec,debug,packet 0d000014 4a131c81 07035845 5c5728f2 0e95452f 0d000014 4df37928 e9fc4fd1
11:16:28 ipsec,debug,packet b3262170 d515c662 0d000014 8f8d8382 6d246b6f c7a8a6a4 28c11de8 0d000014
11:16:28 ipsec,debug,packet 439b59f8 ba676c4c 7737ae22 eab8f582 0d000014 4d1e0e13 6deafa34 c4f3ea9f
11:16:28 ipsec,debug,packet 02ec7285 0d000014 80d0bb3d ef54565e e84645d4 c85ce3ee 0d000014 9909b64e
11:16:28 ipsec,debug,packet ed937c65 73de52ac e952fa6b 0d000014 7d9419a6 5310ca6f 2c179d92 15529d56
11:16:28 ipsec,debug,packet 0d000014 cd604643 35df21f8 7cfdb2fc 68b6a448 0d000014 90cb8091 3ebb696e
11:16:28 ipsec,debug,packet 086381b5 ec427b1f 0d000018 4048b7d5 6ebce885 25e7de7f 00d6c2d3 80000000
11:16:28 ipsec,debug,packet 00000014 afcad713 68a1f1c9 6b8696fc 77570100
11:16:28 ipsec,debug,packet begin.
11:16:28 ipsec,debug,packet seen nptype=1(sa)
11:16:28 ipsec,debug,packet seen nptype=13(vid)
11:16:28 ipsec,debug,packet succeed.
11:16:28 ipsec,debug received Vendor ID: RFC 3947
11:16:28 ipsec,debug,packet received unknown Vendor ID
11:16:28 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-08
11:16:28 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-07
11:16:28 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-06
11:16:28 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-05
11:16:28 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-04
11:16:28 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-03
11:16:28 ipsec,debug received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
11:16:28 ipsec,debug received broken Microsoft ID: FRAGMENTATION
11:16:28 ipsec,debug received Vendor ID: DPD
11:16:28 ipsec,debug,packet remote supports DPD
11:16:28 ipsec,debug Selected NAT-T version: RFC 3947
11:16:28 ipsec,debug,packet total SA len=224
11:16:28 ipsec,debug,packet seen nptype=2(prop)
11:16:28 ipsec,debug,packet proposal #1 len=216
11:16:28 ipsec,debug,packet seen nptype=3(trns)
11:16:28 ipsec,debug,packet transform #1 len=36
11:16:28 ipsec,debug,packet type=Life Type, flag=0x8000, lorv=seconds
11:16:28 ipsec,debug,packet type=Life Duration, flag=0x8000, lorv=3600
11:16:28 ipsec,debug,packet type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
11:16:28 ipsec,debug,packet encryption(aes)
11:16:28 ipsec,debug,packet type=Key Length, flag=0x8000, lorv=256
11:16:28 ipsec,debug,packet type=Authentication Method, flag=0x8000, lorv=pre-shared key
11:16:28 ipsec,debug,packet type=Hash Algorithm, flag=0x8000, lorv=SHA
11:16:28 ipsec,debug,packet hash(sha1)
11:16:28 ipsec,debug,packet type=Group Description, flag=0x8000, lorv=1024-bit MODP group
11:16:28 ipsec,debug,packet hmac(modp1024)
11:16:28 ipsec,debug,packet transform #2 len=36
11:16:28 ipsec,debug,packet type=Hash Algorithm, flag=0x8000, lorv=MD5
11:16:28 ipsec,debug,packet hash(md5)
11:16:28 ipsec,debug,packet transform #3 len=36
11:16:28 ipsec,debug,packet type=Key Length, flag=0x8000, lorv=128
11:16:28 ipsec,debug,packet transform #4 len=36
11:16:28 ipsec,debug,packet transform #5 len=32
11:16:28 ipsec,debug,packet type=Encryption Algorithm, flag=0x8000, lorv=3DES-CBC
11:16:28 ipsec,debug,packet encryption(3des)
11:16:28 ipsec,debug,packet transform #6 len=32
11:16:28 ipsec,debug,packet pair 1:
11:16:28 ipsec,debug,packet 0x48b408: next=(nil) tnext=0x486390
11:16:28 ipsec,debug,packet 0x486390: next=(nil) tnext=0x483ac0
11:16:28 ipsec,debug,packet 0x483ac0: next=(nil) tnext=0x486f70
11:16:28 ipsec,debug,packet 0x486f70: next=(nil) tnext=0x4839a8
11:16:28 ipsec,debug,packet 0x4839a8: next=(nil) tnext=0x483f18
11:16:28 ipsec,debug,packet 0x483f18: next=(nil) tnext=(nil)
11:16:28 ipsec,debug,packet proposal #1: 6 transform
11:16:28 ipsec,debug,packet prop#=1, prot-id=ISAKMP, spi-size=0, #trns=6
11:16:28 ipsec,debug,packet trns#=1, trns-id=IKE
11:16:28 ipsec,debug,packet Compared: DB:Peer
11:16:28 ipsec,debug,packet (lifetime = 86400:3600)
11:16:28 ipsec,debug,packet (lifebyte = 0:0)
11:16:28 ipsec,debug,packet enctype = 3DES-CBC:AES-CBC
11:16:28 ipsec,debug,packet (encklen = 0:256)
11:16:28 ipsec,debug,packet hashtype = MD5:SHA
11:16:28 ipsec,debug,packet authmethod = RSA signatures:pre-shared key
11:16:28 ipsec,debug,packet dh_group = 1024-bit MODP group:1024-bit MODP group
11:16:28 ipsec,debug,packet trns#=2, trns-id=IKE
11:16:28 ipsec,debug,packet hashtype = MD5:MD5
11:16:28 ipsec,debug,packet trns#=3, trns-id=IKE
11:16:28 ipsec,debug,packet (encklen = 0:128)
11:16:28 ipsec,debug,packet trns#=4, trns-id=IKE
11:16:28 ipsec,debug,packet trns#=5, trns-id=IKE
11:16:28 ipsec,debug,packet enctype = 3DES-CBC:3DES-CBC
11:16:28 ipsec,debug,packet (encklen = 0:0)
11:16:28 ipsec,debug,packet trns#=6, trns-id=IKE
11:16:28 ipsec,debug rejected enctype: DB(prop#1:trns#1):Peer(prop#1:trns#1) = 3DES-CBC:AES-CBC
11:16:28 ipsec,debug rejected authmethod: DB(prop#1:trns#1):Peer(prop#1:trns#1) = RSA signatures:pre-shared key
11:16:28 ipsec,debug rejected hashtype: DB(prop#1:trns#1):Peer(prop#1:trns#1) = MD5:SHA
11:16:28 ipsec,debug rejected enctype: DB(prop#1:trns#1):Peer(prop#1:trns#2) = 3DES-CBC:AES-CBC
11:16:28 ipsec,debug rejected authmethod: DB(prop#1:trns#1):Peer(prop#1:trns#2) = RSA signatures:pre-shared key
11:16:28 ipsec,debug rejected enctype: DB(prop#1:trns#1):Peer(prop#1:trns#3) = 3DES-CBC:AES-CBC
11:16:28 ipsec,debug rejected authmethod: DB(prop#1:trns#1):Peer(prop#1:trns#3) = RSA signatures:pre-shared key
11:16:28 ipsec,debug rejected hashtype: DB(prop#1:trns#1):Peer(prop#1:trns#3) = MD5:SHA
11:16:28 ipsec,debug rejected enctype: DB(prop#1:trns#1):Peer(prop#1:trns#4) = 3DES-CBC:AES-CBC
11:16:28 ipsec,debug rejected authmethod: DB(prop#1:trns#1):Peer(prop#1:trns#4) = RSA signatures:pre-shared key
11:16:28 ipsec,debug rejected authmethod: DB(prop#1:trns#1):Peer(prop#1:trns#5) = RSA signatures:pre-shared key
11:16:28 ipsec,debug rejected hashtype: DB(prop#1:trns#1):Peer(prop#1:trns#5) = MD5:SHA
11:16:28 ipsec,debug rejected authmethod: DB(prop#1:trns#1):Peer(prop#1:trns#6) = RSA signatures:pre-shared key
11:16:28 ipsec,debug no suitable proposal found.
11:16:28 ipsec,debug failed to get valid proposal.
For Reference:
This is on 6.1. It seems like somehow it isn’t picking the correct peer, but I can’t figure out why.
6.1 and 6.2 have a few known IPSec bugs.
Try 6.0
Yeah.. I figured that may be the issue.
