L2TP / IPSec tunnel stops working after 6.22 upgrade
We upgraded our RB1100AH2x yesterday from 6.19 to 6.22 and lost our L2TP / IPSec tunnels in the process. The logs are now littered with IPSec errors stating
failed to pre-process ph2 packet.
In the change log for 6.21 I notice that you can no longer employ a blank value for the Policy Group in the Peer policy. We had originally configured our tunnel this way and I suspect that this is the cause of the errors.
Can anyone point me in the right direction on how to resolve this issue?
See relevant config below (note that the first entry in the ipsec peer is note relevant - entry “1” is the one I am most concerned about"
 /ip ipsec peer> print
Flags: X - disabled, D - dynamic
 0 X  address=xx.xx.xx.xx/32 local-address=0.0.0.0 passive=no
      port=500 auth-method=pre-shared-key secret="redacted"
      generate-policy=no policy-template-group=*FFFFFFFF
      exchange-mode=main send-initial-contact=yes
      nat-traversal=no proposal-check=obey hash-algorithm=md5
      enc-algorithm=3des dh-group=modp1024 lifetime=1d
      lifebytes=0 dpd-interval=disable-dpd dpd-maximum-failures=1
 1  D address=0.0.0.0/0 local-address=0.0.0.0 passive=yes port=500
      generate-policy=port-strict policy-template-group=default
      exchange-mode=main-l2tp send-initial-contact=yes
      nat-traversal=yes hash-algorithm=sha1
      enc-algorithm=3des,aes-128,aes-192,aes-256
      dh-group=modp1024 lifetime=1d dpd-interval=2m
      dpd-maximum-failures=5
 /ip ipsec proposal> print
Flags: X - disabled, * - default
 0  * name="default" auth-algorithms=sha1
      enc-algorithms=3des,aes-256-cbc lifetime=30m
      pfs-group=modp1024
this might help
http://forum.mikrotik.com/t/solved-l2tp-ipsec-stoped-working-after-upgrade-to-6-18/79942/8
