I purchased my first RouterBoard today (RB751G-2HnD) running v5.6. I have managed to set it up pretty much as I want. I have been able to set ip PPTP VPN access from my iPhone. I would ideally like to run L2TP as it is more secure. I have tried setting it up without much luck. I have been reading various forums saying that it does not work very well. At this point I don’t know if this is the case or I have not set it up correctly.
My settings are:-
[admin-user@r1] > /interface l2tp-server server print
enabled: yes
max-mtu: 1460
max-mru: 1460
mrru: disabled
authentication: mschap1,mschap2
default-profile: VPN-Profile
[admin-user@r1] > /ppp secret print detail
Flags: X - disabled
1 name="user" service=l2tp caller-id="" password="password"
profile=VPN-Profile routes="" limit-bytes-in=0 limit-bytes-out=0
[admin-user@r1] > /ppp profile print detail
Flags: * - default
0 * name="default" use-mpls=default use-compression=default
use-vj-compression=default use-encryption=default only-one=default
change-tcp-mss=yes
1 name="VPN-Profile" local-address=VPN-Pool remote-address=VPN-Pool
use-mpls=default use-compression=default use-vj-compression=default
use-encryption=default only-one=default change-tcp-mss=default
dns-server=172.16.0.1
2 * name="default-encryption" use-mpls=default use-compression=default
use-vj-compression=default use-encryption=yes only-one=default
change-tcp-mss=yes
[admin-user@r1] > /ip pool print detail
0 name="dhcp_pool1" ranges=172.16.0.100-172.16.0.254
1 name="VPN-Pool" ranges=172.16.0.220-172.16.0.230
[admin-user@r1] > /ip ipsec peer print detail
Flags: X - disabled
0 address=0.0.0.0/0 port=500 auth-method=pre-shared-key secret="sharedkey"
generate-policy=yes exchange-mode=main send-initial-contact=yes
nat-traversal=no my-id-user-fqdn="" proposal-check=obey
hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d
lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
[admin-user@r1] > /ip firewall filter print detail
0 chain=input action=accept protocol=udp dst-port=500
1 chain=input action=accept protocol=udp dst-port=1701
2 chain=input action=accept protocol=udp dst-port=4500
3 chain=input action=accept protocol=ipsec-esp
Any advice given would be very much appreciated
