Hello there!
Some time ago in our company has been setted a task to realize a VPN for remote user connections from external networks and for stretching the network between two offices. We decided to start from VPN for remote users. Model of router is RB3011. One of interfaces (eth1) on this router is connected to dedicated IP address by ISP. Other inteface (eth9) is connected to switch Cisco 3560, on which serve local network 192.168.67.0/24. Did everything by instruction on https://bozza.ru/art-248.html (instruction in russian, so nevermind) when was configuring the VPN.
As a result connection works, IP address dynamically provides from VPN pool. I can connect to MikroTik web-admin panel (192.168.67.13), but can’t connect to another local services (even can’t ping). What is the problem with may be?
I’ve attached a short scheme of connection to the topic. Can give more information if it will be require.
P.S. I tested using of arp-proxy setting and static routes on client devices. It didn’t help…
Much thanks in advance!
