L2TP/IPSec with RSA problem on Windows
Hi, I’m in dead end. I got MK with L2TP/IPSec VPN with rsa authorization .. It works fine with Android device. Bud I’m unable connect with Windows client.
  1. I downloaded cert CA and User
  2. merge it with openssl
  3. import it.
But it not works, on android I can select certificate. But on windows it do not prompt me to select certificate so I know problem in windows somewhere or at way how I generated certificates, or import it.
Certificates was generated by IPSet tutorial from Mikrotik wiki ( From Ikev2 RSA) https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Road_Warrior_setup_Ikev2_RSA_auth
My config:
# sep/08/2017 12:59:13 by RouterOS 6.40.3
# software id = HHJ5-08K2
# model = RouterBOARD 750G r3
# serial number = 6F3806AED257
add arp=proxy-arp name=bridge_local
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=default-dhcp ranges=192.168.88.10-192.168.88.50
add name=pool_vpn ranges=192.168.88.51-192.168.88.60
add address-pool=default-dhcp disabled=no interface=bridge_local name=defconf
/ppp profile
add bridge=bridge_local local-address=192.168.88.2 name=vpn_profile_L2TP \
    remote-address=pool_vpn
add bridge=bridge_local interface=ether2-master
/interface l2tp-server server
set default-profile=default enabled=yes ipsec-secret=123456789
add comment=defconf interface=ether2-master list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
    192.168.88.0
add address=109.105.43.202/27 interface=ether1 network=109.105.43.192
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router.lan
/ip ipsec peer
add address=0.0.0.0/0 dh-group=modp1024 disabled=yes generate-policy=\
    port-override secret=123456789
add address=0.0.0.0/0 auth-method=rsa-signature certificate=server1 comment=\
    "with cert" dh-group=modp1024 generate-policy=port-override
add distance=1 gateway=109.105.43.193
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/ppp secret
add name=user1 password=user1 profile=vpn_profile_L2TP
/system clock
set time-zone-name=Europe/Prague
/system logging
add topics=ipsec,!debug
add topics=l2tp
/system ntp client
set enabled=yes primary-ntp=216.239.35.8
/system routerboard mode-button
set enabled=no on-event=""
/tool mac-server
add interface=ether2-master
/tool mac-server mac-winbox
Certificates at mikrotik:
Certificates at windows:
Windows vpn conf:
Log at moment when connection is made from windows:
Do you have some idea ? What is wrong ?
I don’t do this often, but I remember that Windows was picky, not 100% sure, but I think it wanted certificates not in current user, but in local computer store. And linked manual page shows local computer too, so try that.
Hi, thanks for response but do not help.. I try It now, import cert. to local computer storage but still same error.
