I have two ISPs on ether 1 and ether 2, each of them have different Public IP, I have set up an L2TP/IPSEC VPN server but only one of the public IP is available for the clients to connect, the ether 1 (ISP 1) must be down for the ether 2 (ISP 2) to able to accept VPN clients, but I want that both of the Public IP can cater VPN at any given time, do you guys have any idea on how to do this? Thanks!
Can you please share your config?
/export hide-sensitive file=anythingyoulike
I have no clue if the VPN service is prohibited to a single interface…
/ip ipsec profile
add dh-group=modp1024 dpd-interval=3m20s dpd-maximum-failures=20
enc-algorithm=aes-256,3des name=profile2
/ip ipsec peer
This entry is unreachable
add name=peer33 passive=yes profile=profile2
/ip ipsec proposal
add enc-algorithms=aes-256-cbc,3des lifetime=0s name=proposal11 pfs-group=
none
add name=dhcp_pool0 ranges=192.168.11.50-192.168.11.254
add name=vpn_pool1 ranges=172.8.99.2-172.8.99.254
add name=vpn_pool2 ranges=172.9.99.2-172.9.99.254
/ppp profile
add change-tcp-mss=yes dns-server=1.1.1.1 local-address=6.7.8.17 name=
profile1 only-one=no remote-address=vpn_pool1 use-encryption=required
add local-address=7.3.6.3 name=profile2 remote-address=vpn_pool2
add change-tcp-mss=yes dns-server=1.1.1.1 local-address=6.7.10.17 name=
profile3 only-one=no remote-address=vpn_pool2 use-encryption=required
/tool user-manager customer
set admin access=
own-routers,own-users,own-profiles,own-limits,config-payment-gw
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=profile1 enabled=yes
keepalive-timeout=disabled max-mru=1480 max-mtu=1480 use-ipsec=yes
/interface pptp-server server
set default-profile=profile2
add address=Isp1PublicIP interface=ether1 network=gatewayisp1
add address=Isp2PublicIP interface=ether2 network=gatewayisp2
/ip dhcp-client
add add-default-route=no disabled=no interface=ether8
set servers=8.8.8.8
/ip firewall address-list
add address=172.8.99.0/24 list="VPN Users"
add address=10.0.101.0/24 list=Cloud
add address=192.168.200.0/22 list=200pips
add address=192.168.21.0/24 list=21pips
add address=someip list="ABU IP"
add address=192.168.1.0/24 list=APPpips
add address=172.9.99.0/24 list="VPN GlobeUsers"
add action=drop chain=input protocol=icmp src-address-list="!ABU IP"
add action=accept chain=input dst-port=1701 protocol=udp
add action=accept chain=forward disabled=yes dst-address-list=Cloud
src-address-list="VPN Users"
add action=masquerade chain=srcnat dst-address-list=Cloud out-interface=
ether8 src-address-list="VPN Users"
ether8 routing-mark=VPN_GLOBE src-address-list="VPN GlobeUsers"
add action=masquerade chain=srcnat dst-address-list=21pips out-interface=
add action=masquerade chain=srcnat dst-address-list=200pips out-interface=
add action=masquerade chain=srcnat dst-address-list=APPpips out-interface=
add action=masquerade chain=srcnat src-address-list="VPN Users"
add action=masquerade chain=srcnat routing-mark=VPN_GLOBE src-address-list=
"VPN GlobeUsers"
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec identity
add generate-policy=port-override peer=peer33
/ip ipsec policy
add proposal=proposal11 template=yes
add distance=1 gateway=GatewayIsp1 routing-mark=VPN_GLOBE
add distance=1 gateway=GatewayIsp2
add distance=1 dst-address=10.0.101.0/24 gateway=192.168.200.1
add distance=1 dst-address=192.168.1.0/24 gateway=192.168.200.118
add distance=1 dst-address=192.168.21.0/24 gateway=192.168.200.1
add distance=1 dst-address=192.168.170.0/24 gateway=192.168.200.1
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=8825
set api-ssl disabled=yes
/ppp secret
#I removed some users
add name=vpn_abu profile=profile1 service=l2tp
add name=csc profile=profile1 service=l2tp
add name=abu_alsons profile=profile3 service=l2tp
/system clock
set time-zone-name=Asia/Manila
/system identity
set name=ABU-VPN
/system logging
add topics=firewall
/system ntp client
set enabled=yes primary-ntp=121.58.193.100
/tool mac-server
/tool mac-server ping
set enabled=no
/tool user-manager database
set db-path=user-manager
