L2TP IPSEC
I configured L2TP IPsec and its working fine except one issue..i can not ping any device under the lan only the router.
Do you have any idea? Thanks
If you assigned an IP address to the L2TP dialin that is within your LAN subnet, you will need to enable proxy-arp on your LAN interface.
i have it enabled on the ports that i am using for lan.
ok i forgot to enable it under the bridge also… :confused:
