I had this L2TP tunnel working fine for almost a month. But now suddenly it’s not working properly anymore. The only thing that I changed in the routers recently was that I removed the admin user from all routers changing for a different username with full access.
Here is my config …
L2TP-Server Router (OFFICE1)
[me@cmi.bra] /ppp secret> print detail
Flags: X - disabled
1 name="soho.usa" service=l2tp caller-id="" password="123456" profile=default-encryption
local-address=172.16.1.1 remote-address=172.16.1.2 routes="192.168.2.0/24 172.16.1.2 1" limit-bytes-in=0
limit-bytes-out=0
[me@cmi.bra] /interface l2tp-server server> print
enabled: yes
max-mtu: 1460
max-mru: 1460
mrru: disabled
authentication: pap,chap,mschap1,mschap2
default-profile: default-encryption
Remote Office (OFFICE2)
[me@soho-usa] /interface l2tp-client> print
0 R name="l2tp-cmi" max-mtu=1460 max-mru=1460 mrru=disabled connect-to=XXX.XXX.XXX.XXX user="soho.usa"
password="123456" profile=default-encryption add-default-route=no dial-on-demand=no allow=pap,chap,mschap1,mschap2
The L2TP tunnel is established fine as always been, I can ping both sides, but I cannot access anything on the OFFICE. I can ssh the OFFICE1 router fine, but it stops responding after a couple seconds, and if I try to access a webpage in the OFFICE1, I can see that it finds the server, but keeps loading the page forever. It seems to be a problem with TCP, but it’s just a guess.
I have no clue what happened because as I already said, I haven’t changed any critical configuration in any router. I have rebooted both router coutless times, but no luck.
Any help is appreciated,
Thanks,
