L2TP - old tunnel is not closed
Hello!
I am working on failover script and found, that after change route distance of my ISP and disable/enable lt2p connection, my l2tp connect much longer. In log I found rows:
But, when I disable/enable lt2p connection without change routes, it connect much faster:
Why it happens and what mean “old tunnel is not closed”? Can I close it from script?
Did you find a solution?
No. :frowning:
same problem on 2 vpn-servers
hEX S and RB4011, RouterOS 6.43.8/6.43.12
same problem on RB3011UiAS, firmware 6.43.12
temporal solution:
ppp - profiles - limits - only one => NO
This is BUG. Router don’t close old connection…
