L2TP over IPSec / PPP Secret Caller ID
Hi All,
I am trying to lock down an L2TP over IPSec VPN road warrior using an IP Range and MAC address. (or at least one of the two.) Reading up the Caller ID states that if used with L2TP then it is a IP Address it is expecting. This works, however if I try to an IP Range, it does not work.
“For PPTP and L2TP it is the IP address a client must connect from.”
http://wiki.mikrotik.com/wiki/Manual:PPP_AAA
Looks it may not support an IP Range.
I also tried the MAC address as well and that didn’t work either (just because I saw some documentation stating when used with PPPOE it was using MAC) so just figured why not before posting here..
When an IP Range is input it tries to connect and the log shows shows 'but was expected from xxx.xxx.xxx and is missing the last .xxx part of the IP.
I am using v5.26, maybe someone can confirm this is as expected… I know I could just filter I guess via Firewall rules but I was just hoping to cut it off at the connection point right away if possible.
Maybe I am missing something or another spot to input this information.. or a spot to use the ‘Address List’ would be fine too, but I don’t see that anywhere for the L2TP or PPP Secrets…
