I have been trying for some time to try and get L2TP to work between my Android Motorola Droid and my Mikrotik router running RouterOS 4.10 without any success. I’ve tried with and without IPSec. With IPSec, the IPSec layer seems to connect just fine, the problem seems to be when L2TP is trying to authenticate. I have followed the directions at http://wiki.mikrotik.com/wiki/MikroTik_RouterOS_and_Windows_XP_IPSec/L2TP. Interestingly enough if I try and connect with my Windows 7 netbook the IPSec fails with:
Jul 31 03:09:22 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec invalid length of payload
Here’s the logs from connecting my Motorola Droid:
Jul 31 02:06:39 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec respond new phase 1 negotiation: 173.x.xxx.xx[500]<=>192.168.1.101[500]
Jul 31 02:06:39 firewall.doofusnet.org ipsec ISAKMP-SA established 173.x.xxx.xx[500]-192.168.1.101[500] spi:72ccee7f18384ca1:a6c764e6351f2e30
Jul 31 02:06:39 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec purging spi=84222348.
Jul 31 02:06:39 firewall.doofusnet.org ipsec generated policy, deleting it.
Jul 31 02:06:39 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec get a src address from ID payload 192.168.1.101[0] prefixlen=32 ul_proto=17
Jul 31 02:06:39 firewall.doofusnet.org ipsec get dst address from ID payload 173.x.xxx.xx[1701] prefixlen=32 ul_proto=17
Jul 31 02:06:39 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec pfkey spddelete(inbound) sent.
Jul 31 02:06:39 firewall.doofusnet.org ipsec purging spi=231280416.
Jul 31 02:06:39 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec pfkey X_SPDDELETE failed: No such file or directory
Jul 31 02:06:39 firewall.doofusnet.org ipsec pfkey X_SPDDELETE failed: No such file or directory
Jul 31 02:06:40 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec respond new phase 2 negotiation: 173.x.xxx.xx[500]<=>192.168.1.101[500]
Jul 31 02:06:40 firewall.doofusnet.org ipsec Update the generated policy : 192.168.1.101/32[0] 173.x.xxx.xx/32[1701] proto=udp dir=in
Jul 31 02:06:40 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec authtype mismatched: my:hmac-md5 peer:hmac-sha
Jul 31 02:06:40 firewall.doofusnet.org ipsec IPsec-SA established: ESP/Transport 192.168.1.101[0]->173.x.xxx.xx[0] spi=238457803(0xe3693cb)
Jul 31 02:06:40 routerboard.doofusnet.org.0.168.192.in-addr.arpa ipsec IPsec-SA established: ESP/Transport 173.x.xxx.xx[0]->192.168.1.101[0] spi=23809854(0x16b4f3e)
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug debug: tunnel 124 entering state: wait-ctl-conn
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:06:41 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=124
Jul 31 02:06:41 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:06:42 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:06:42 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:06:42 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:06:42 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:42 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:06:42 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:06:42 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:06:42 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:06:42 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:06:42 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=124
Jul 31 02:06:42 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=124
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:43 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:43 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=124
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:45 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:45 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:47 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:47 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:47 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:47 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:47 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:47 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:47 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:47 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:47 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:47 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:47 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:47 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=124
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:49 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:49 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:51 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:51 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:51 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:51 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:51 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:51 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:51 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:51 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:51 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:51 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:51 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:51 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:53 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:53 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:53 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:53 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:53 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:53 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:53 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:53 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:53 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:53 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:53 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:53 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:55 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:55 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:55 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:55 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:55 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:55 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:55 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:55 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:55 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:55 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:55 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:55 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:55 mail kernel: SuSE-FW-DROP-DEFAULT IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:40:34:95:08:00 SRC=173.x.xxx.xx DST=255.255.255.255 LEN=124 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=5678 DPT=5678 LEN=104
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=124
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:06:57 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug debug: tunnel 124 received no replies, disconnecting
Jul 31 02:06:57 firewall.doofusnet.org l2tp,debug debug: tunnel 124 entering state: dead
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug debug: tunnel 125 entering state: wait-ctl-conn
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:06:59 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=125
Jul 31 02:06:59 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:00 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:00 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:00 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:00 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:00 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:00 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:00 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:00 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:00 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:00 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=125
Jul 31 02:07:00 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:01 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=125
Jul 31 02:07:01 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:03 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=125
Jul 31 02:07:03 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:05 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:05 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:05 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:05 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:05 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:05 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:05 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:05 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:05 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:05 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:05 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:05 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:07 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=125
Jul 31 02:07:07 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:09 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:09 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:09 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:09 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:09 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:09 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:09 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:09 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:09 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:09 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:09 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:09 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:11 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:11 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:11 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:11 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:11 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:11 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:11 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:11 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:11 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:11 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:11 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:11 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:13 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:13 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:13 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:13 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:13 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:13 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:13 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:13 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:13 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:13 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:13 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:13 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:15 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=125
Jul 31 02:07:15 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:17 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:17 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:17 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:17 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:17 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:17 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:17 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:17 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:17 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:17 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:17 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:17 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:17 firewall.doofusnet.org l2tp,debug debug: tunnel 125 received no replies, disconnecting
Jul 31 02:07:17 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug debug: tunnel 125 entering state: dead
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug debug: tunnel 126 entering state: wait-ctl-conn
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:19 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=126
Jul 31 02:07:19 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:20 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:20 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:20 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:20 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:20 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:20 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:20 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:20 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:20 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:20 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=126
Jul 31 02:07:20 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=126
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: rcvd control message from 192.168.1.101:52439
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=0, nr=0
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRQ
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“anonymous”
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x3
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=63917
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=1
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Challenge=0xd3:00:23:0a:24:f7:51:60:a6:34:09:9e:7b:e7:3d:11
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: d6:13:0c:61:0d:ee:b9:c4:4f:6d:50:5e:0e:be:59:1b
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: sent control message (ack) to 192.168.1.101:52439
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=1, nr=1
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=0, session-id=0, ns=1, nr=0
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=StopCCN
Jul 31 02:07:21 firewall.doofusnet.org l2tp,debug,packet debug: (M) Result-Code=6
Jul 31 02:07:21 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug debug: received message with wrong tunnel id, ignoring
Jul 31 02:07:23 firewall.doofusnet.org l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:23 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:23 firewall.doofusnet.org l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:23 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:23 firewall.doofusnet.org l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:23 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:23 firewall.doofusnet.org l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:23 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:23 firewall.doofusnet.org l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:23 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=126
Jul 31 02:07:23 firewall.doofusnet.org l2tp,debug,packet debug: (M) Receive-Window-Size=4
Jul 31 02:07:27 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: sent control message to 192.168.1.101:52439
Jul 31 02:07:27 firewall.doofusnet.org l2tp,debug,packet debug: tunnel-id=63917, session-id=0, ns=0, nr=1
Jul 31 02:07:27 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Message-Type=SCCRP
Jul 31 02:07:27 firewall.doofusnet.org l2tp,debug,packet debug: (M) Protocol-Version=0x01:00
Jul 31 02:07:27 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Framing-Capabilities=0x1
Jul 31 02:07:27 firewall.doofusnet.org l2tp,debug,packet debug: (M) Bearer-Capabilities=0x0
Jul 31 02:07:27 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Firmware-Revision=0x1
Jul 31 02:07:27 firewall.doofusnet.org l2tp,debug,packet debug: (M) Host-Name=“Aaron Firewall”
Jul 31 02:07:27 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: Vendor-Name=“MikroTik”
Jul 31 02:07:27 firewall.doofusnet.org l2tp,debug,packet debug: (M) Assigned-Tunnel-ID=126
Jul 31 02:07:27 routerboard.doofusnet.org.0.168.192.in-addr.arpa l2tp,debug,packet debug: (M) Receive-Window-Size=4
Here are the logs my phone generated:
D/VpnManager(24213): succeeded to connect to VPN service
D/com.android.settings.vpn.AuthenticationActor(24213): ~~~~~~ connect() succeeded!
D/dalvikvm( 1176): GC_EXTERNAL_ALLOC freed 1591 objects / 92304 bytes in 106ms
D/VpnSettings(24213): received connectivity: IPSec: connected? CONNECTING err=0
I/SProxy_mtpd(24254): Stop VPN daemon: mtpd
D/SProxy_mtpd(24254): mtpd is stopped after 0 msec
D/SProxy_mtpd(24254): stopping mtpd, success? true
I/SProxy_racoon(24254): Stop VPN daemon: racoon
D/SProxy_racoon(24254): racoon is stopped after 0 msec
D/SProxy_racoon(24254): stopping racoon, success? true
D/VpnService(24254): Local IP: 192.168.1.101, if: tiwlan0
D/VpnService(24254): VPN UP: down
I/SProxy_racoon(24254): Start VPN daemon: racoon
D/racoon (24392): Waiting for control socket
D/SProxy_racoon(24254): racoon is running after 0 msec
D/dalvikvm( 1083): GC_EXTERNAL_ALLOC freed 13581 objects / 862992 bytes in 142ms
D/racoon (24392): Received 3 arguments
I/racoon (24392): ipsec-tools 0.7.3 (http://ipsec-tools.sf.net)
I/racoon (24392): 192.168.1.101[500] used as isakmp port (fd=9)
I/racoon (24392): 192.168.1.101[500] used for NAT-T
I/racoon (24392): 192.168.1.101[4500] used as isakmp port (fd=11)
I/racoon (24392): 192.168.1.101[4500] used for NAT-T
I/SProxy_racoon(24254): got data from control socket: 3
D/AlarmManagerService( 1083): Kernel timezone updated to 420 minutes west of GMT
D/dalvikvm( 1182): GC_FOR_MALLOC freed 8024 objects / 468424 bytes in 57ms
I/SProxy_mtpd(24254): Start VPN daemon: mtpd
D/MobileDataStateTracker( 1083): default Received state= DISCONNECTED, old= CONNECTED, reason= dataDisabled, apnTypeList= default,mms,hipri
D/NetworkStateTracker( 1083): setDetailed state, old =CONNECTED and new state=DISCONNECTED
D/ConnectivityService( 1083): ConnectivityChange for mobile: DISCONNECTED/DISCONNECTED
D/ConnectivityService( 1083): getMobileDataEnabled returning true
V/ConnectivityService( 1083): Switching to already connected WIFI
D/ConnectivityService( 1083): adding dns 192.168.0.1 for WIFI
I/ActivityManager( 1083): Start proc com.motorola.calendar for broadcast com.motorola.calendar/com.motorola.motosync.service.EasBootReceiver: pid=24661 uid=10010 gids={3003}
D/Tethering( 1083): Tethering got CONNECTIVITY_ACTION
D/Tethering( 1083): MasterInitialState.processMessage what=3
E/HierarchicalStateMachine( 1083): TetherMaster - unhandledMessage: msg.what=3
D/SProxy_mtpd(24254): mtpd is running after 0 msec
D/SProxy_mtpd(24254): service not yet listen()ing; try again
D/mtpd (24669): Waiting for control socket
D/mtpd (24669): Received 20 arguments
I/keystore( 1014): uid: 1016 action: g → 1 state: 1 → 1 retry: 4
I/mtpd (24669): Using protocol l2tp
I/mtpd (24669): Connecting to 173.x.xxx.xx port 1701
I/racoon (24392): no in-bound policy found: 173.x.xxx.xx/32[1701] 192.168.1.101/32[0] proto=udp dir=in
I/racoon (24392): IPsec-SA request for 173.x.xxx.xx queued due to no phase1 found.
I/racoon (24392): initiate new phase 1 negotiation: 192.168.1.101[500]<=>173.x.xxx.xx[500]
I/racoon (24392): begin Identity Protection mode.
I/mtpd (24669): Connection established (socket = 11)
D/mtpd (24669): Sending SCCRQ (local_tunnel = 44537)
I/SProxy_mtpd(24254): got data from control socket: 20
I/racoon (24392): received Vendor ID: DPD
I/racoon (24392): received broken Microsoft ID: FRAGMENTATION
I/racoon (24392): ISAKMP-SA established 192.168.1.101[500]-173.x.xxx.xx[500] spi:72ccee7f18384ca1:a6c764e6351f2e30
I/racoon (24392): initiate new phase 2 negotiation: 192.168.1.101[500]<=>173.x.xxx.xx[500]
I/racoon (24392): IPsec-SA established: ESP/Transport 173.x.xxx.xx[0]->192.168.1.101[0] spi=23809854(0x16b4f3e)
I/racoon (24392): IPsec-SA established: ESP/Transport 192.168.1.101[500]->173.x.xxx.xx[500] spi=238457803(0xe3693cb)
D/mtpd (24669): Timeout → Sending SCCRQ
