L2TP Port and PPoE port
Can you program a L2TP port to work through PPPoE port, ie: could one used the PPPoE port for a L2TP Dial in and the PPPoE for internet access?
sure. what’s problem?
how would you set it up?
and would it affect your internet access?
I still don’t understand, what the problem is… just create necessary ppp interfaces =)
on the router I have a Dyndns Script running with a PPPoE client out to the internet. Every time I try to “Dial in” to the router from my Laptop, it can never find the L2tp Server, and when I log on to the Router using my web browser I can see the routers HTML page, but cant connect to the router.
Advice please
any firewall filtering?..
No, How would you suggest I set that up?
nope, by default all is allowed
check with packet sniffer, whether your router receives L2TP packets at all - maybe your ISP is blocking it some way…
