I try to create an l2tp client. I configured the tunnel and it works but when I try to reach a devise on the other side I keep getting errors.
The connection works and also I manually added a route to the LAN subnet using VPN as gateway on the remote computer, telling it: “to reach 192.168.x.x you have to use VPN tunnel remote IP as gateway”.
The l2tp interface is marked as running, but when I try to ping any lan devices I get a network unreachable from the other side of the tunnel. I try to ping directly via my router
The problem basically is that on the other side of the tunnel there is a firewall rule blocking everything that’s not cumming from my local ip. Can I change the ip shown in the other side of the tunnel?
