L2tp problem
Hello ,
I have 5 static valid ip address in the mikrotik .
I can connect L2TP connection to the first IP address , but can not connect to other ip address .
can help ?
Yes … it has been like that for several years, possibly forever.
The interesting thing is that if you set up several IP’s in the same /24 range and don’t pick a primary, but set up all of them with the same /24 mask, the IP for the L2TP server will be random after each reboot. Usually however it steps back 1 every time you reboot. So x.x.x.254 first x.x.x.253 second etc …
This caused me to use PPTP for a long time, at least until I figured this out.
GL
