l2tp problem
i setup l2tp vpn and this is my peers :
[admin@MikroTik] > ip ipsec peer print
Flags: X - disabled
0 address=0.0.0.0/0 port=500 auth-method=pre-shared-key secret=“9126879054”
generate-policy=yes exchange-mode=main send-initial-contact=yes
nat-traversal=yes my-id-user-fqdn=“” proposal-check=obey
hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d
lifebytes=0 dpd-interval=disable-dpd dpd-maximum-failures=1
[admin@MikroTik] >
and this is my nat rules :
admin@MikroTik] > ip firewall nat print
0 X ;;; default configuration
chain=srcnat action=masquerade out-interface=External
1 chain=srcnat action=masquerade src-address=192.168.214.0/24
[admin@MikroTik] >
but only 1 person can connect to l2tp in same time if second person connect to l2tp that user can not browse any website but other protocols like pptp,sstp works fine,
can you help me?
Thanks,
