L2TP Remote server response
Hi, All!
I have a problem with connection to remote file server through L2TP with IPSec. I set L2TP connection and its works fine, but my problem is that POOLs in both networks are same (192.168.1.0/24).
When I try to open remote server with IP: 192.168.1.250 opens local PC with same IP. If I try from network with different by 192.168.1.0/24 addresses Remote Server respond and everything is ok.
Is there option to open Remote Server from my network with current settings or I have to change addresses mandatory?
Situation:
My LAN: (192.168.1.0/24) -----------------------------------------------------------> Remote LAN: 192.168.1.0/24
VLAN Local Address: 192.168.46.0/24 (VPN Pool: 192.168.46.100 - 192.168.46.199)
Thank You
