L2TP routing issue - SOLVED
Hello everybody.
I am new in this forum and new with handeling mikrotik materials.
The requirements are : I have an office with many access controllers linked to an access control server, everything is alright inside the internal LAN. The office needs to add more access controller far the office in other cities. For this, we have already one RB3011 ARM and many little Routers access points which support L2TP clients to be set in other cities.
I set Up a L2TP server without ipsec in th RB3011:
The Constat is :
Incoming connexions :
I can ping from 10.20.30.40 to 10.10.0.40
I can ping from 10.20.30.40 to 172.17.98.2 & 172.10.98.1 & 10.100.200.1 & 10.100.200.2
bref, I can ping from 10.20.30.40 to everywhere.
outcoming
I can ping from 10.10.0.40 to 172.17.98.1 & 172.17.98.2
I can NOT ping from 10.10.0.40 to 10.20.30.40 or to 10.100.200.2
from the mikrotik itself using tools–>ping
I can ping from IT to 10.10.0.40 & 172.17.98.2
I can ping from IT to 10.100.200.1 and 10.100.200.2
BUT when I ping from mikrotik to 10.20.30.40 I have response succesful from 10.100.200.2 !!!
I doubt the Firewall of the office is the cause but when I did an experience by disconnecting the firewall cable and plug it to my laptop and put 172.17.98.2 inside my NIC I had the same issue and constats!!.
Please help to solve this issue and thank you very much in advance for your responses (sorry for my bad english)
the topologie :
You should post your router configuration with an
/export hide-sensitve
We than can walk trough it and guide you towards a solution.
Are the L2TP-clients also MikroTik, if so please post the config of it as well
[quote=atmane post_id=683471 time=1535850405 user_id=127930]
when I ping from mikrotik to 10.20.30.40 I have response succesful from 172.17.98.253
[/quote]
Please do the ping command above from the command line (press the [Terminal] button in Winbox or Webfig or log in using ssh to get a command line window, write ping 10.20.30.40 there and press [Enter]) and copy-paste here the output. I hesitate to believe what I read regarding the result :slight_smile:
[admin@MikroTik] > export hide-sensitive
sep/04/2018 19:07:51 by RouterOS 6.42.7
software id = 1EBQXXXX
model = RouterBOARD 3011UiAS
serial number = 8EED0XXXXXXX
add fast-forward=no name=sahcom protocol-mode=none
add admin-mac=CC:2D:E0:XX:XX:XX auto-mac=no comment=defconf name=bridge protocol-mode=none
set [ find default-name=ether1 ] advertise=100M-full loop-protect=off
set [ find default-name=ether2 ] advertise=100M-full loop-protect=off
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=sahcom comment=defconf interface=ether2
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
/interface l2tp-server server
set enabled=yes keepalive-timeout=disabled
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=172.17.98.1/24 interface=sahcom network=172.17.98.0
add address=81.192.X.Y/28 interface=ether1 network=81.192.X.Y
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=172.17.98.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=172.17.98.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input
add action=accept chain=forward
add action=accept chain=output
add distance=2 gateway=81.192.X.Y
add distance=1 dst-address=10.10.0.0/16 gateway=172.17.98.2
add distance=1 dst-address=10.20.30.0/24 gateway=10.100.200.2
/lcd
set time-interval=hour
/ppp secret
add local-address=10.100.200.1 name=sahcom01 remote-address=10.100.200.2 routes=10.20.30.0/24
add name=sahcom02 service=l2tp
add name=sahcom03 service=l2tp
add name=sahcom04 service=l2tp
add name=sahcom05 service=l2tp
/system clock
set time-zone-name=Africa/Casablanca
/system routerboard settings
set silent-boot=no
/system scheduler
add interval=2h name="auto reboot" on-event="/system reboot" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=sep/04/2018 start-time=
18:00:00
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
[quote=sindy post_id=683564 time=1535910460 user_id=110692]
[/quote]
[/quote]
I CHANGED the 172.17.98.253 with 10.100.200.2
I found the problem myself, The Issue was in the client side.
I used a PLANET VDR301n client and has the NAPT enabled by default. When I disabled it the issue disappeared.
