Anyone have the same issue or a solution to this?
I have a site2site vpn with ipsec up, maybe this is the problem.
I think I have posted all the config you need. I log the following ppp, l2tp and ipsec,!packet
This is an export from my working L2TP with IPSec setup I’m testing with. It may be of some help to you. The X.X.X.X values were my WAN IP/Gateway/Network. The *'s were where the same password I had was (Both client and shared password were the same in my setup). The username for the L2TP connection was ‘mikrotik’.
[admin@MikroTik] > export
# oct/07/2014 20:29:57 by RouterOS 6.20rc7
/interface pptp-server
add disabled=yes name=pptp-in1 user=mikrotik
set [ find default-name=ether1 ] speed=1Gbps
set [ find default-name=ether2 ] disabled=yes
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc,aes-192-cbc,aes-256-cbc
add name=dhcp ranges=10.10.10.10-10.10.11.254
add address-pool=dhcp disabled=no interface=ether2 name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
set 1 dns-server=8.8.8.8,8.8.4.4 local-address=10.10.10.2 remote-address=dhcp use-ipv6=no
/system logging action
set 2 remember=yes
/interface l2tp-server server
set enabled=yes ipsec-secret=******** use-ipsec=yes
/interface pptp-server server
set enabled=yes
add address=X.X.X.X/23 comment="default configuration" interface=ether1 network=X.X.X.0
add address=10.10.10.1/23 interface=ether1 network=10.10.10.0
add address=10.10.10.0/23 gateway=10.10.10.1 netmask=23
set servers=8.8.8.8,8.8.4.4
add chain=forward
add chain=input
add chain=output
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes in-interface=l2tp-in1 new-routing-mark=vpnIn
add chain=prerouting
/ip firewall service-port
set sip disabled=yes
/ip ipsec peer
add enc-algorithm=3des,aes-128,aes-192,aes-256 exchange-mode=main-l2tp generate-policy=port-override secret=********
add distance=1 gateway=ether1 routing-mark=vpnIn
add distance=1 gateway=X.X.X.1
/ip upnp
set allow-disable-external-interface=no
/ppp secret
add name=mikrotik password=******** profile=default-encryption service=l2tp
/snmp
set trap-community=public
