I have suckcessful with configure IPSEC beetween two sites Mikrotik1 and Mikrotik2, i can Ping from PC1 to PC2 and others. I can use RDP and get response from www.
The problem is when i configure L2TP on Mikrotik1. When i connect from PC-L2TP everything is ok with lan on Mikrotik1. When I ping PC2 or Laptop2 i get response,
When i try connect via RDP i get response to fill login and pass but it stuck on “securing the connection”. Also when i try to open www give response connection timed out.
I Try to change MTU on Mikrotik1 to 1172 (this is the last good value when i got the response)
ping 172.222.22.185 -f -l 1172 -t
Pinging 172.222.22.185 with 1172 bytes of data:
Reply from 172.222.22.185: bytes=1172 time=55ms TTL=126
Reply from 172.222.22.185: bytes=1172 time=40ms TTL=126
Also i’m try to add on mikrotik1
/ip firewall mangle add action=change-mss chain=forward dst-address=172.222.22.185 log=yes new-mss=
1172 passthrough=yes protocol=tcp tcp-flags=syn
add action=change-mss chain=forward disabled=yes new-mss=1172 passthrough=yes
And still nothing. I cannot connect via RDP. Please help
