Hi!
How to direct output l2tp-connection to new WAN after disconnect\reconnect?
I have 2 routing tables.
I try to catch 1 packet of new l2tp-connection in mangle output with “connection state = new” option, but not seen any packets.
How to solve?
Hi!
How to solve?
Not sufficient information (your rule may be at wrong position in the chain), but most likely the lifetime of the connection in the firewall’s connection tracker (180s for UDP) is longer than the pause between the L2TP failure and the re-connection attempt following the failure, so the connection tracker treats an actually new connection to the same destination as if it was the old one. This happens (if it does) because RouterOS follows the L2TP recommendation so although it is acting as a client, it uses port 1701 also at local side, so the connection tracker cannot distinguish between the old and new attempt as all the distinctive fields of a UDP connection (local IP and port, remote IP and port) are the same.
Yes, you are right.
And i have no idea, how to reconnect l2tp via new wan.
There is a four-letter word describing the situation, starting with letter ж.
Do you use L2TP over IPsec or a plain L2TP? In either case, the solution might be to capture the initial packet, analyse it using wireshark, compose a hex pattern matching that packet using the content match condition, and use it together with a size match condition in a rule which would add a short-lived item to /ip firewall address-list. A script scheduled for every second would look for that address-list item and if found, it would remove the existing /ip firewall connection, so the next retransmission of the initial packet would create a new connection and would also be treated as a connection-state=new packet.
Спасибо a lot.
I am also think about script to check l2tp-connection state and removing connection from conntrack table.
But i am still hope to find native solution (without scripts).
