L2TP user can't connect to any device on network
OS: 6.46.2
Scenario: from remote location I connect to my mikrotik via L2TP/IPsec. I am able to ping the local IP of the router (10.1.1.1) but nothing else on the network (10.1.1.2, 10.1.1.3, etc).
My L2TP VPN IP is from the same subnet (10.1.1.39). I tried connecting from a different device with a different username, same result.
All I get is Request timeout for icmp_seq.
This used to work just last week. Since then the only thing I changed is upgrading to 6.46.2 (from 6.46.1).
I do not see any roles in ip firewall filter blocking this. Does anyone have any idea?
If client’s address is from same subnet, it requires proxy ARP on LAN interface. If it would be missing, it wouldn’t work. But I don’t see any reason why would upgrade remove it.
The interface had arp=enable, once I changed it to arp=proxy-arp ping was working again.
Thank you very much!
