I am using RouterOS 6.37.1 (stable) on the VPN server.
When my client from UAE uses L2TP VPN on iOS 11 via WiFi everything works for him.
When he uses 4G mobile data nothing opens. Just no Internet.
What could be the problem ?
Is that your only client or do you have more?
L2TP/IPsec only works when there is a single client per IP address.
On 4G there will normally be a NAT between you and the client, and when another client is behind the same NAT, it will fail.
Also, it will likely fail when there is double-NAT. You can work around that problem by:
It may be that you can do the same by updating to the current version and check that exchange mode “main l2tp” is
active instead of “main”. I am not sure that this fixes it.
