I have 3 companies using MK routers with VPN’s for their clients. Now with people working from home they may be getting taxed, but only 1 is consistently having issues. This only concerns Windows 10 clients, btw.
There many posts here about this issue, which comes down to the error:
l2tp connection attempt failed because the security layer encountered
Although I’ve read many of the posts concerning this issue, so far I have found no resolution.
In this case there are 4 people potentially using the VPN. So far it seems only 3 are on at the same time. I have heard no complaints from one of the clients.
Another client has had this issue and discovered that if she merely reboot her modem and router, the trouble goes away.
But just today another client has been having this issue. It was only after deleting her VPN setting in Windows and recreating it, that the trouble goes away.
Anyhow, although it is my belief that it is likely something wrong with Windows 10, I can’t keep having to nurse each client back up. Are there recommendations on what settings I might consider changing, or maybe just changing everyone over to a different VPN protocol.
The settings are used are very similar to the one’s here:
https://justit.eu/mikrotik-l2tpipsec-vpn/
