Please help me to find a reason why my VPN L2TP connection is not running.
Because I have problem from outside my network to connect first I tried to connect I decided to run first from my LAN.
Mikrotik 192.168.29.254
Win7: 192.168.29.180
Firewall
;;; OpenVPN
chain=input action=accept protocol=tcp dst-port=1460 log=no log-prefix=""
chain=input action=accept protocol=udp dst-port=500 log=no log-prefix=""
chain=input action=accept protocol=udp dst-port=1701 log=no log-prefix=""
chain=input action=accept protocol=udp dst-port=4500 log=no log-prefix=""
chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
chain=input action=accept protocol=ipsec-ah log=no log-prefix=""
After this I got logs :
19:11:27 l2tp,debug,packet VPN l2to: rcvd control message from 192.168.29.180:1701 to 192.168.29.254:1701
19:11:27 l2tp,debug,packet VPN l2to: tunnel-id=0, session-id=0, ns=0, nr=0
19:11:27 l2tp,debug,packet VPN l2to: (M) Message-Type=SCCRQ
19:11:27 l2tp,debug,packet VPN l2to: (M) Protocol-Version=0x01:00
19:11:27 l2tp,debug,packet VPN l2to: (M) Framing-Capabilities=0x1
19:11:27 l2tp,debug,packet VPN l2to: (M) Bearer-Capabilities=0x0
19:11:27 l2tp,debug,packet VPN l2to: Firmware-Revision=0xa00
19:11:27 l2tp,debug,packet VPN l2to: (M) Host-Name="mainframe"
19:11:27 l2tp,debug,packet VPN l2to: Vendor-Name="Microsoft"
19:11:27 l2tp,debug,packet VPN l2to: (M) Assigned-Tunnel-ID=48
19:11:27 l2tp,debug,packet VPN l2to: (M) Receive-Window-Size=8
19:11:27 l2tp,info VPN l2to: first L2TP UDP packet received from 192.168.29.180
19:11:27 l2tp,debug VPN l2to: tunnel 104 entering state: wait-ctl-conn
19:11:27 l2tp,debug,packet VPN l2to: sent control message to 192.168.29.180:1701 from 192.168.29.254:1701
19:11:27 l2tp,debug,packet VPN l2to: tunnel-id=48, session-id=0, ns=0, nr=1
19:11:27 l2tp,debug,packet VPN l2to: (M) Message-Type=SCCRP
19:11:27 l2tp,debug,packet VPN l2to: Firmware-Revision=0x1
19:11:27 l2tp,debug,packet VPN l2to: (M) Host-Name="CoreRouter"
19:11:27 l2tp,debug,packet VPN l2to: Vendor-Name="MikroTik"
19:11:27 l2tp,debug,packet VPN l2to: (M) Assigned-Tunnel-ID=104
19:11:27 l2tp,debug,packet VPN l2to: (M) Receive-Window-Size=4
19:11:27 l2tp,debug,packet VPN l2to: (M) Challenge=0x03:87:b6:c9:5c:d1:81:3b:a8:a6:10:4c:ed:69:0b:36
19:11:27 l2tp,debug,packet VPN l2to: PPPoE-Relay-Response-Capability=
19:11:27 l2tp,debug,packet VPN l2to: PPPoE-Relay-Forward-Capability=
19:11:27 l2tp,debug,packet VPN l2to: tunnel-id=104, session-id=0, ns=1, nr=1
19:11:27 l2tp,debug,packet VPN l2to: (M) Message-Type=SCCCN
19:11:27 l2tp,debug,packet VPN l2to: (M) Response=0x1d:5f:96:ed:fc:b2:e1:67:b9:74:29:d7:82:77:89:a4
19:11:27 l2tp,debug VPN l2to: tunnel 104 received bad auth. response, stopping
19:11:27 l2tp,debug,packet VPN l2to: tunnel-id=48, session-id=0, ns=1, nr=2
19:11:27 l2tp,debug,packet VPN l2to: (M) Message-Type=StopCCN
19:11:27 l2tp,debug,packet VPN l2to: (M) Result-Code=1
19:11:27 l2tp,debug VPN l2to: tunnel 104 entering state: stopping
19:11:27 l2tp,debug,packet VPN l2to: rcvd control message (ack) from 192.168.29.180:1701 to 192.168.29.254:1701
19:11:27 l2tp,debug,packet VPN l2to: tunnel-id=104, session-id=0, ns=3, nr=1
19:11:27 l2tp,debug,packet VPN l2to: tunnel-id=104, session-id=0, ns=2, nr=1
19:11:27 l2tp,debug,packet VPN l2to: (M) Message-Type=ICRQ
19:11:27 l2tp,debug,packet VPN l2to: (M) Assigned-Session-ID=1
19:11:27 l2tp,debug,packet VPN l2to: (M) Call-Serial-Number=0
19:11:27 l2tp,debug,packet VPN l2to: (M) Bearer-Type=0x2
19:11:27 l2tp,debug,packet VPN l2to: 1(vendor-id=311)=0x3c:ed:fd:2a:9c:3b:dc:43:86:bc:99:82:33:d1:99:e1
19:11:27 l2tp,debug VPN l2to: tunnel 104 received message in stopping state, dropping
19:11:27 l2tp,debug,packet VPN l2to: tunnel-id=104, session-id=0, ns=3, nr=2
19:11:27 l2tp,debug VPN l2to: tunnel 104 entering state: dead
