L2TP VPN Question
Not sure if this is the correct place for this but here goes.
We are using the L2TP server function on our cloud router. We are using two profiles, one for our Mikrotik to Mikrotik connectivity and one for our PC to mikrotik connectivity. The device to device connectivity works perfectly but we are experiencing issues when connecting with a PC/Mac. The connection is established and works well if you don’t leave it standing for too long. If the machine is left connected to the Mikrotik and you aren’t actively working the connection seems to stop working. Although my PC indicates that it is still connected to the cloud router via the L2TP VPN I cannot access any of my machines. Ping doesn’t work either. The systems are not accessible in any way.
Any insight into what the problem might be will be greatly appreciated.
