L2TP VPN: Viola GPRS Gateway doesn't conect to Mikrotik
Hello all!
I have one device Viola GPRS Gateway (violasystems.com) and Mikrotik router.
Mikrotik has static public IP address, Viola tries to connect it using L2TP protocol, but it can’t.
I get errors on Viola:
<15> Sep 18 12:19:23 l2tp-vpn: Waiting GPRS to become available
<15> Sep 18 12:19:23 l2tp-vpn: GPRS available on interface ppp0
<15> Sep 18 12:19:24 l2tp-vpn: /bin/route add -host 84.50.xxx.xxx dev ppp0
<30> Sep 18 12:19:26 l2tpd[291]: l2tpd version 0.69 started on ViolaArctic2 PID:291
<30> Sep 18 12:19:26 l2tpd[291]: Connecting to host 84.50.xxx.xxx, port 1701
<28> Sep 18 12:19:26 l2tpd[291]: Using hostname ‘ViolaArctic2’
<30> Sep 18 12:19:28 l2tpd[291]: Connection established to 84.50.xxx.xxx, 1701. Local: 38670, Remote: 33.
<30> Sep 18 12:19:28 l2tpd[291]: Calling on tunnel 38670
<31> Sep 18 12:19:28 l2tpd[291]: check_control: Received out of order control packet on tunnel 33 (0 != 1)
<31> Sep 18 12:19:28 l2tpd[291]: handle_packet: bad control packet!
<30> Sep 18 12:19:29 l2tpd[291]: Call established with 84.50.xxx.xxx, Local: 4339, Remote: 1, Serial: 1
<31> Sep 18 12:19:33 l2tpd[291]: result_code_avp: avp is incorrect size. 8 < 10
<28> Sep 18 12:19:33 l2tpd[291]: handle_avps: Bad exit status handling attribute 1 (Result Code) on mandatory packet.
<30> Sep 18 12:19:33 l2tpd[291]: Call 4339 to 84.50.xxx.xxx disconnected
<31> Sep 18 12:19:34 l2tpd[291]: check_control: Received out of order control packet on tunnel 33 (2 != 3)
<31> Sep 18 12:19:34 l2tpd[291]: handle_packet: bad control packet!
<31> Sep 18 12:19:35 l2tpd[291]: result_code_avp: avp is incorrect size. 8 < 10
<28> Sep 18 12:19:35 l2tpd[291]: handle_avps: Bad exit status handling attribute 1 (Result Code) on mandatory packet.
<30> Sep 18 12:19:35 l2tpd[291]: Connection 33 closed to 84.50.xxx.xxx, port 1701 (Result Code)
I know there are Viola’s errors, but maybe somebody can comment these errors because they are concerned with L2TP protocol?
In Google I didn’t find any topic concerned with these errors, only source files of L2TP Daemon (http://mia.ece.uic.edu/cgi-bin/lxr/http/source/avp.c?v=l2tpd-0.69).
Any suggestions?
Thaks!
