L2TP with RADIUS
Hi!
What I’m trying to achive:
  • VPN acces to local network (L2TP, IPSec)
  • authentication by Active Directory accounts
What have I done so far:
  • Create RADIUS Server on Windows Server 2019
  • it is possible to connect via ‘standard’ MikroTik account
What is not working:
  • No acces to local network (from device connected via VPN)
  • No access to internet (from device connected via VPN)
  • RADIUS is not working properly (I’ve recive message 'The remote connection aws dnieded, because the user name and pasword combination you provided is not recognized, or the selected authentication protocol is not permitted on the remote access server")
I was using some tutorials, but in every tutorial I’ve got different advices. I’m not a network-guy, just developer, who have to configure simple company network. :wink:
Here is configuration, I would really appreciate Your help fixing and setting it up.
AD/DNS Server: 192.168.7.70
Router IP: 192.168.7.1
add admin-mac=74:4D:28:24:69:0B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] arp=proxy-arp
set [ find default-name=ether3 ] arp=proxy-arp
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    password=*** use-peer-dns=yes user=***
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=4 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country=poland disabled=no distance=indoors frequency=2447 \
    frequency-mode=regulatory-domain mode=ap-bridge ssid=*** \
    wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
    *** wpa2-pre-shared-key=***
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
    aes-256-cbc,aes-128-cbc pfs-group=none
add name=dhcp ranges=192.168.7.200-192.168.7.254
add name=VPN ranges=192.168.7.150-192.168.7.199
add name=VMs ranges=192.168.7.100-192.168.7.149
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add dns-server=192.168.7.70 local-address=192.168.7.150 name=Vpn-clients \
    remote-address=VPN
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
/interface l2tp-server server
set authentication=mschap2 default-profile=Vpn-clients enabled=yes \
    ipsec-secret=test use-ipsec=required
add address=192.168.7.1/24 comment=defconf interface=ether2 network=\
    192.168.7.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=192.168.7.0/24 comment=defconf gateway=192.168.7.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.7.1 name=router.lan
    established,related,untracked
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp
add action=accept chain=input dst-port=1701 protocol=udp
add action=accept chain=input protocol=ipsec-esp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    ipsec-policy=out,none out-interface=pppoe-out1 out-interface-list=WAN
/ip ssh
set allow-none-crypto=yes
/ppp aaa
set use-radius=yes
/ppp secret
add local-address=192.168.7.149 name=test password=test profile=\
    default-encryption remote-address=192.168.7.151
/radius
add address=192.168.7.70 called-id=192.168.7.70 domain=agilerolocal.pl \
    secret=AgileroSecret123 service=ppp src-address=192.168.7.1
/system clock
set time-zone-name=Europe/Warsaw
/system logging
add topics=firewall
add topics=debug
add topics=l2tp
add topics=ipsec
add topics=l2tp
add topics=radius
add topics=ipsec,!packet
add topics=!pppoe
/tool mac-server
/tool mac-server mac-winbox
For Mikrotik and Windows AD integration I used this tutorial
https://mivilisnet.wordpress.com/2018/10/01/how-to-integrate-your-mikrotik-router-with-windows-ad/
Unable to access LAN from VPN client
http://forum.mikrotik.com/t/pptp-vpn-can-ping-mikrotik-cant-ping-any-device-in-lan/78040/1
You are the best, now I have access to local resources.
I still have a problem with RADIUS. I’ve used the same tutorial, but something is wrong.
When i enter to RADIUS settings in webfig there are Pending 0, Requests 0 etc, so it looks like a problem in router L2TP configuration.
EDIT:
Below logs:
13:12:54 l2tp,debug,packet rcvd control message from 37.47.100.44:1701 to 185.3.113.7:1701
13:12:54 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
13:12:54 l2tp,debug,packet     (M) Message-Type=SCCRQ
13:12:54 l2tp,debug,packet     (M) Protocol-Version=0x01:00
13:12:54 l2tp,debug,packet     (M) Framing-Capabilities=0x1
13:12:54 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
13:12:54 l2tp,debug,packet     Firmware-Revision=0xa00
13:12:54 l2tp,debug,packet     (M) Host-Name="AG1.domainlocal.pl"
13:12:54 l2tp,debug,packet     Vendor-Name="Microsoft"
13:12:54 l2tp,debug,packet     (M) Assigned-Tunnel-ID=21
13:12:54 l2tp,debug,packet     (M) Receive-Window-Size=8
13:12:54 l2tp,info first L2TP UDP packet received from 37.47.100.44
13:12:54 l2tp,debug tunnel 62 entering state: wait-ctl-conn
13:12:54 l2tp,debug,packet sent control message to 37.47.100.44:1701 from 185.3.113.7:1701
13:12:54 l2tp,debug,packet     tunnel-id=21, session-id=0, ns=0, nr=1
13:12:54 l2tp,debug,packet     (M) Message-Type=SCCRP
13:12:54 l2tp,debug,packet     Firmware-Revision=0x1
13:12:54 l2tp,debug,packet     (M) Host-Name="MikroTik"
13:12:54 l2tp,debug,packet     Vendor-Name="MikroTik"
13:12:54 l2tp,debug,packet     (M) Assigned-Tunnel-ID=62
13:12:54 l2tp,debug,packet     (M) Receive-Window-Size=4
13:12:54 l2tp,debug,packet     tunnel-id=62, session-id=0, ns=1, nr=1
13:12:54 l2tp,debug,packet     (M) Message-Type=SCCCN
13:12:54 l2tp,debug tunnel 62 entering state: estabilished
13:12:54 l2tp,debug,packet sent control message (ack) to 37.47.100.44:1701 from 185.3.113.7:1701
13:12:54 l2tp,debug,packet     tunnel-id=21, session-id=0, ns=1, nr=2
13:12:54 l2tp,debug,packet     tunnel-id=62, session-id=0, ns=2, nr=1
13:12:54 l2tp,debug,packet     (M) Message-Type=ICRQ
13:12:54 l2tp,debug,packet     (M) Assigned-Session-ID=1
13:12:54 l2tp,debug,packet     (M) Call-Serial-Number=0
13:12:54 l2tp,debug,packet     (M) Bearer-Type=0x2
13:12:54 l2tp,debug,packet     1(vendor-id=311)=0xd0:a6:c5:c6:34:d0:da:40:b3:87:37:da:b8:f0:7b:d3
13:12:54 l2tp,debug session 1 entering state: wait-connect
13:12:54 l2tp,debug,packet     tunnel-id=21, session-id=1, ns=1, nr=3
13:12:54 l2tp,debug,packet     (M) Message-Type=ICRP
13:12:54 l2tp,debug,packet     tunnel-id=62, session-id=1, ns=3, nr=2
13:12:54 l2tp,debug,packet     (M) Message-Type=ICCN
13:12:54 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=72200000
13:12:54 l2tp,debug,packet     (M) Framing-Type=0x1
13:12:54 l2tp,debug,packet     Proxy-Authen-Type=4
13:12:54 l2tp,debug session 1 entering state: established
13:12:54 l2tp,debug,packet     tunnel-id=21, session-id=0, ns=2, nr=4
13:12:54 l2tp,ppp,debug <37.47.100.44>: LCP lowerup
13:12:54 l2tp,ppp,debug <37.47.100.44>: LCP open
13:12:54 l2tp,debug,packet rcvd control message (ack) from 37.47.100.44:1701 to 185.3.113.7:1701
13:12:54 l2tp,debug,packet     tunnel-id=62, session-id=0, ns=4, nr=2
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd LCP ConfReq id=0x0
13:12:54 l2tp,ppp,debug,packet    <mru 1400>
13:12:54 l2tp,ppp,debug,packet    <magic 0x4a193c8f>
13:12:54 l2tp,ppp,debug,packet    <pcomp>
13:12:54 l2tp,ppp,debug,packet    <accomp>
13:12:54 l2tp,ppp,debug,packet    <callback 0x06>
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: sent LCP ConfReq id=0x1
13:12:54 l2tp,ppp,debug,packet    <mru 1450>
13:12:54 l2tp,ppp,debug,packet    <magic 0x4d427964>
13:12:54 l2tp,ppp,debug,packet    <auth  mschap2>
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: sent LCP ConfRej id=0x0
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd LCP ConfAck id=0x1
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd LCP ConfReq id=0x1
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: sent LCP ConfAck id=0x1
13:12:54 l2tp,ppp,debug <37.47.100.44>: LCP opened
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: sent CHAP Challenge id=0x1
13:12:54 l2tp,ppp,debug,packet     <challenge len=16>
13:12:54 l2tp,ppp,debug,packet     <name MikroTik>
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd LCP Ident id=0x3
13:12:54 l2tp,ppp,debug,packet     MSRAS-0-AG1
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd LCP Ident id=0x2
13:12:54 l2tp,ppp,debug,packet     MSRASV5.20
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd LCP Ident id=0x4
13:12:54 l2tp,ppp,debug,packet     \D0\A6\C5\C64\D0\DA@\B3\877\DA\B8\F0{\D3
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd CHAP Response id=0x1
13:12:54 l2tp,ppp,debug,packet     <response len=49>
13:12:54 l2tp,ppp,debug,packet     <name DOMAINLOCAL\name.surname>
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: sent CHAP Failure id=0x1
13:12:54 l2tp,ppp,debug,packet     E=691 R=0 C=E71055BFF1495C9F3A007C9A2212001D V=3 M=bad username or password
13:12:54 l2tp,ppp,error <37.47.100.44>: user name.surname authentication failed - radius timeout
13:12:54 l2tp,ppp,debug <37.47.100.44>: LCP close
13:12:54 l2tp,ppp,debug <37.47.100.44>: LCP closed
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: sent LCP TermReq id=0x2
13:12:54 l2tp,ppp,debug,packet     user name.surname authentication failed - radius timeout
13:12:54 l2tp,ppp,debug,packet  <37.47.100.44>: rcvd LCP TermAck id=0x2
13:12:54 l2tp,ppp,debug <37.47.100.44>: LCP lowerdown
13:12:54 l2tp,ppp,debug <37.47.100.44>: CCP close
13:12:54 l2tp,ppp,debug <37.47.100.44>: BCP close
13:12:54 l2tp,ppp,debug <37.47.100.44>: IPCP close
13:12:54 l2tp,ppp,debug <37.47.100.44>: IPV6CP close
13:12:54 l2tp,ppp,debug <37.47.100.44>: MPLSCP close
13:12:54 l2tp,ppp,debug <37.47.100.44>: LCP down event in initial state
13:12:54 l2tp,debug,packet     tunnel-id=62, session-id=1, ns=4, nr=2
13:12:54 l2tp,debug,packet     (M) Message-Type=CDN
13:12:54 l2tp,debug,packet     (M) Result-Code=3
13:12:54 l2tp,debug,packet         Error-Code=0
13:12:54 l2tp,debug,packet     tunnel-id=21, session-id=0, ns=2, nr=5
13:12:54 l2tp,debug session 1 entering state: stopping
13:12:54 l2tp,debug session 1 entering state: dead
13:12:54 l2tp,debug,packet     (M) Message-Type=StopCCN
13:12:54 l2tp,debug,packet     (M) Result-Code=1
13:12:54 l2tp,debug tunnel 62 entering state: stopping
13:12:54 l2tp,debug,packet     tunnel-id=62, session-id=0, ns=5, nr=2
13:12:54 l2tp,debug,packet     (M) Result-Code=6
13:12:54 l2tp,debug,packet     tunnel-id=21, session-id=0, ns=3, nr=6
13:12:54 l2tp,debug tunnel 62 entering state: dead
So radius timeout is the reason. How to fix that?
Can anyone help me?
If L2TP client is Windows, run this command in Windows administrative command window (cmd → run as administrator), then restart Windows:
reg add HKLM\SYSTEM\CurrentControlSet\Services\PolicyAgent /v AssumeUDPEncapsulationContextOnSendRule /t REG_DWORD /d 0x2 /f
Thank You for Your answer, unfortunatelly nothing changed, when I’m trying to log in in log appears:
10:03:26 l2tp,ppp,debug,packet  <37.47.65.10>: rcvd CHAP Response id=0x1
10:03:26 l2tp,ppp,debug,packet     <response len=49>
10:03:26 l2tp,ppp,debug,packet     <name DOMAINLOCAL\name.surname>
10:03:27 l2tp,ppp,debug,packet  <37.47.65.10>: sent CHAP Failure id=0x1
10:03:27 l2tp,ppp,debug,packet     E=691 R=0 C=CE3A3E24935FBBC97F062DA010A1CF08 V=3 M=bad username or password
10:03:27 l2tp,ppp,error <37.47.65.10>: user name.surname authentication failed - radius timeout
10:03:27 l2tp,ppp,debug <37.47.65.10>: LCP close
10:03:27 l2tp,ppp,debug <37.47.65.10>: LCP closed
10:03:27 l2tp,ppp,debug,packet  <37.47.65.10>: sent LCP TermReq id=0x3
10:03:27 l2tp,ppp,debug,packet     user name.surname authentication failed - radius timeout
10:03:27 l2tp,ppp,debug,packet  <37.47.65.10>: rcvd LCP TermAck id=0x3
And all counters in RADIUS tab does not increase.
W guess, I found a reason - I can’t ping my AD Server (192.168.7.70) using udp 1812/1813.
Could You help me create firewall rules?
Can anyone help me?
It is really important for me to make it work, I ran out of ideas. :frowning:
Try to use simpler RADIUS configuration
/radius
add address=192.168.7.70 secret=AgileroSecret123 service=ppp src-address=192.168.7.1
You tried this from Mikrotik?
