L3 VXLAN Drops client traffic
Hi all,
I’m working on implementing a VXLAN configuration between 4 - CRS504-4XQ switches and I’m running into issues where clients cannot pass traffic over the VXLAN connection with l3-offloading on. Here’s the topology:
R1 R2 R3 R4
  • All switches are using the latest software at the time of writing: 7.18.2
    Switches are able to ping each other over the VXLAN connection with both hw=on and hw=off on the VXLAN configuration
    Clients cannot pass traffic over VXLAN with hw=on but can with hw=off
    Clients have a tagged VLAN that is then connected to the untagged VXLAN, the same configuration is on the bridge as well
Configurations are attached!
Thanks for all of the help!
R4.txt.txt (4.04 KB)
R1.txt.txt (4.98 KB)
R2.txt.txt (3.97 KB)
R3.txt.txt (3.16 KB)
I am facing the same problem, have you managed to find a fix for this ?
Or has anyone else managed to solve this ?
@Mikrotik Support Can you assist for this ?
Bump…
I have similar issue, did you find s solution ?
