L3VPN Specific PATH for different VRF
my question is if is there anyway to attach a specific path (using MPLS-TE or similar…) to a specific VRF.
Example:
R1: BGP Peer, holding 3 Vrf (ClientA, ClientB, ClientC)
R8: BGP Peer, holding 3 Vrf (ClientA, ClientB, ClientC)
R1 – (MPLS Cloud) – R8
(With Multiple paths)
Both RB’s are peering each other and sending each other the L3VPN routes.
Can i use different paths for ClientA ClientB, etc…?
How would it be done, routing its traffic thru MPLS-TE Tunnels?
Can i route directly thru the TE interface or should i create a /30 network on both ends?
Can i do this with specific protocols ? (P2P, VoIP, HTTP…)
Thank you in advantage.
noone?
hope to knew how to explain it good.
x
