I have a question, with an L4 / P1 license I can do Virtual Ap on an LGH 5
Yes. But is it really necessary? Maybe there is better and cheaper option. What is your usecase?
ok I explain, in my country we get internet for wifi, then for each connection the provider assigns me an dhcp ip address with a bandwidth of 2Mbps, then I want to make a virtual AP to get another ip address for dhcp and so on way to increase more 2Mbps channels in my network, the question is that my LHG5 has an Lv3 license and does not allow me to create Virtual AP, which you suggest
Looks like you do not need virtual ap but virtual client. Or use your lhg5 in bridging mode, if possible, and on second router behind it set multiple vlans as wans. Just an idea, I have not tried it.
