L7 RegExp for .mp4 and .flv file types
Looking to identify video content coming from youtube. I’ve already got the content filter sending all traffic containing “youtube.com” to the Youtube chain. Within the Youtube chain I want to pick out only .flv and .mp4 content. To the best of my understanding, the right way to do this is to use L7 filters. I do not know regular expressions. Does anyone have regexp strings that I could use to achieve my goal?
I checked http://l7-filter.sourceforge.net/protocols
but it doesn’t have any regexp for mp4 and flv. But it have some useful regexp and you may need them in future.
Yeah, I’ve already searched the forum and found that most L7 threads inevitably link to that site. Looked there first.
/ip firewall layer7-protocol
add name="Extension \" .mp4 \"" regexp="\\.(mp4)"
add name="Extension \" .flv \"" regexp="\\.(flv)"
Are these really work?
I should go and try :slight_smile:
Thanks, Muqatil. I’ll give those a try and post the results. It looks like this format would work for pretty much any sort of file extension, right?
yes it does. And it works for me :slight_smile:
Okay, so I think I’ve got the L7 filters put together right but the counter for the “packet-mark” rules is not getting ticked when I hit youtube and start a video. Here’s how I’m identifying the traffic:
/ip firewall mangle
add action=jump chain=prerouting content=youtube.com disabled=no jump-target=\
    youtube
add action=add-dst-to-address-list address-list=Youtube address-list-timeout=\
    5m chain=youtube comment=\
    "All packets processed in this chain should be added to Youtube list." \
    disabled=no dst-port=80 protocol=tcp
add action=mark-connection chain=youtube disabled=no dst-address-list=Youtube \
    new-connection-mark=youtube_conn passthrough=yes
add action=mark-packet chain=output connection-mark=youtube_conn disabled=no \
    layer7-protocol="Extension \".mp4 \"" new-packet-mark=youtube_mp4 \
    passthrough=yes
    layer7-protocol="Extension \".mp4 \"" new-packet-mark=youtube_flv \
    passthrough=yes
And here are the filters:
add name="Extension \".mp4 \"" regexp="\\.(mp4)"
add name="Extension \".flv \"" regexp="\\.(flv)"
Did I typo or am I just conceptualizing this wrong?
Why did you set chain=output on your packet marker? That chain checks only the packets generated by the router itself. if i did not misunderstood your conf, change it to forward chain
/ip firewall mangle
    youtube
add action=mark-packet chain=forward connection-mark=youtube_conn disabled=no \
    passthrough=yes src-address-list=Youtube
Okay, I corrected a couple of things here. First of all, I wasn’t specifying the address list I wanted it to pull from. Second, I did have it in the output chain. I’m running a proxy on this device. My logic was that since it was a proxy redirect, it would be seen as coming from the router, but you’re right. It should be in the forward chain.
The idea here is to have packets containing the “youtube.com” string get kicked to the “Youtube” chain. There, the IPs will be added to an address list. IPs on the address list get marked with the “youtube_conn” mark and sent through the L7 filter. The “packet-mark” rules still aren’t getting hit.
BTW, if you know of a more effective way to accomplish what I’m attempting here, I would not be opposed to a complete redesign. All I want is to slow just video traffic from youtube.
Actually i didn’t know about the proxy service. Forward Chain would not be used by your traffic. Your logic was correct :smiley:
Can you use prerouting chain or is it used for other purposes?
What did you have in mind for the prerouting chain? Can you give me an example?
