Lab: Bonding interface loses packets when slave is disabled
Hello team!
I’ve created a lab to test bonding and I’m finding a strange behaviour. When I disable one the slave interfaces, ping starts to lose packets.
Can you advise what am I doing wrong?
Thanks in advance!
Bonding = bond0 (slaves = ether1,ether3) Bonding = bond0 (slaves = ether1,ether3)
ip address = 10.1.1.1/30 ip address = 10.1.1.2/30
Some more info
[admin@routeros-1] > interface bonding print
0 R name=“bond0” mtu=1500 mac-address=50:00:00:02:00:00 arp=enabled
arp-timeout=auto slaves=ether1,ether3 mode=balance-rr primary=none
link-monitoring=mii arp-interval=100ms arp-ip-targets=“”
mii-interval=100ms down-delay=0ms up-delay=0ms lacp-rate=30secs
transmit-hash-policy=layer-2 min-links=0
[admin@routeros-1] > interface print
NAME TYPE ACTUAL-MTU L2MTU
0 RS ether1 ether 1500
1 R ether2 ether 1500
2 RS ether3 ether 1500
3 R bond0 bond 1500 1500
[admin@routeros-1] > ip address print
ADDRESS NETWORK INTERFACE
0 10.1.1.1/30 10.1.1.0 bond0
[admin@routeros-1] > ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 10.1.1.0/30 10.1.1.1 bond0 0
[admin@routeros-1] > export
nov/25/2021 19:43:59 by RouterOS 6.49.1
software id =
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-full speed=1Gbps
set [ find default-name=ether2 ] advertise=
set [ find default-name=ether3 ] advertise=
/interface bonding
add name=bond0 slaves=ether1,ether3
add address=10.1.1.1/30 interface=bond0 network=10.1.1.0
/system identity
set name=routeros-1
[admin@routeros-2] > interface bonding print
0 R name=“bond0” mtu=1500 mac-address=50:00:00:03:00:00 arp=enabled
[admin@routeros-2] > interface print
3 R ether4 ether 1500
4 R bond0 bond 1500 1500
[admin@routeros-2] > ip address print
0 10.1.1.2/30 10.1.1.0 bond0
[admin@routeros-2] > ip route print
0 ADC 10.1.1.0/30 10.1.1.2 bond0 0
[admin@routeros-2] > export
nov/25/2021 19:43:33 by RouterOS 6.49.1
software id =
set [ find default-name=ether4 ] advertise=
/interface bonding
add address=10.1.1.2/30 interface=bond0 network=10.1.1.0
/system identity
set name=routeros-2
