Labels not Refreshing. Bug? Unreliable polling too.
I update labels with snmp info and custom functions using VBS. Under 3.5 the Labels do not refresh reliably. Under the 2.2 they worked great.
The system is set for a 30 second label refresh and the Device icon is set to default on the refresh time. I changed the refresh time on another device but that did not help either.
Any ideas?
Example: Under Appearance on a device I have
[Device.Name]
[Device.AddressesCommaList]
[Device.CustomField1]
([oid(“iso.org.dod.internet.mgmt.mib-2.system.sysName.0”)]) < this should update as the data changes.>
Addon here 10-8-10
I just discovered that the polling is not working good either. A lot of item will not detect a loss of ping response even though the device is off.
Usually is I create a new object that matches one that is not working, the new one will work.
The file was imported from 2.2 and things have been copied. I took clean install of the 4.?? beta, I could not get it to update a label/appearance with snmp data either.
