Lack of Power?
Hello
I just stick a sr2 and a cm9 in the same wrap
the cm9 can hear cpe’s no probs but the cpes are reporting about a 10db drop in what they can hear. (as if the base was turned down to 10db)
Would lack of power do this?
Its a very low usage site, I was thinking of switching to a rb110, would that help?
check if cards alone work correctly
check if (if possible) you replace cards with equal anything change.
RB112 will work with SR2 and CP9 card
but check first, maybe there is no need in getting new equipment, what if some cabling is damaged or something.
