LACP and DHCP Snooping Question
Hoi RouterOS Folks
This, maybe, sounds like a stupid question… i have a scenario with a CRS3xx switch and two link SFP+ LACP Bonding as uplink interfaces to another CRS3xx switch (core) where the trusted DHCP server ist located. Now i read that DHCP snooping is not possible with hardware offloading LACP bonding active? Does this only affect DHCP bonding with option 82 enabled?
I have a lab env here with DHCP snooping (w/o option 82) enabled and LACP bonding as uplink (trusted), with different CRS3xx switches as access and core and it seems like it works?!
Im a bit confused what scenarios this “DHCP snooping does not work with HW offloaded LACP bondings” are affected… maybe you can enlighten me :slight_smile:
Firmware is v7.14.3 on every switch.
Best Greetings
From my understanding it should behave like a trusted port, just because DHCP Snooping is not “working” on this bond.
Found something in the documentation:
“Starting from RouterOS v7.17, DHCP snooping is supported with hardware offloading bonding interfaces.”
Source:
https://help.mikrotik.com/docs/display/ROS/CRS3xx%2C+CRS5xx%2C+CCR2116%2C+CCR2216+switch+chip+features
Once 7.17 is released, we should have the support for this on some devices.
