Hi all,
I tried to setup an aggregated link on two SFP+ ports between a CRS328 switch and a Ubiquiti US-48.
The Ubiquiti AFAIK only does aggregation via LACP, so the first attempt has been with SwOS and it kinda worked (nothing to do, just left both ports on the SwOS as passive): both ports recognized the trunk on the two ports as the same (1) with the same partner mac id from the US-48. However a couple of days later, looking at my router logs I noticed a storm of:
ether2: bridge RX looped packet - MAC 18:fd:74:XX:XX:XX -> ff:ff:ff:ff:ff:ff VID 1 ETHERTYPE 0x0800 IP UDP 0.0.0.0:68 -> 255.255.255.255:67
The router is a HeX S router (recently updated to 7.9.2) which is connected to the Ubiquiti US-48 on the ether2 port.
As soon as I disconnect one of the two SFP+ connectors, the storm of looped packet stops immediately.
I tried to reboot the CRS328 in ROS and set up the bond but immediately hit the wall as I cannot remove the 2 sfp+ ports from the bridge (couldn’t remove - ether devices are not removable), and apparently cannot add them to the bond either if they’re part of the bridge. How should I proceed?
I’m a bit puzzled on the cause of this as I got the feeling (before noticing the log) that the aggregation worked.
