Hello experts,
I’m looking for a RouterOS 7.x equivalent feature for “LACP fallback”, usually used during the client PXE booting phase. I have a couple of MLAG connected CRS326-24S+2Q+ with RouterOS v7.3.1 (stable). The scenario I’m looking for is perfectly described in this Arista KB[1].
Can’t this be just a scheduled script that monitors link status and switches between 802.3ad and active-standby with primary interface? Not a single config line like Arista, but still may do the trick
I thought LACP was the term used for bonding two etherports from one device into another so it appears as one interface ???
“Link Aggregation Control Protocol (LACP) is a standard that allows switches to combine multiple physical Ethernet links into a single logical link. This process is called link aggregation.”
This would be extremely helpful. When a Talos node boots without LACP (because it still needs to be configured) the switch LACP needs to be disabled somehow for the configuration to happen. Once the node starts with LACP PDUs, then restart LACP peering.
