LACP with dell 8024f
Hi
got a stacked 8024f and I want to bond via lacp the 2 sfp+ ports from a CCR1036-8G-2S+ to the 8024f.
I setup the ports as LACP and setup the routeros as bonded lacp.
unfortunately didn’t work couldn’t activate on the dell’s so i switched to manual / static port-channel.
I set routeros to roundrobin-alb
any one else been able to do this
any pitfalls I should look for ?
A
no sure what version you run on - just had a bad fall with ccr trying to bond to cisco switch. cisco lacp channel falls over after 30 seconds complaining about miss configuration of ethernet interfaces - not port channels - looks like low level packet scrambling/loop at ethernet interface on CCR. All works fine on a RB750G 6.10 - so just have to wait what MT will pick up over time to fix it. sadly, my ccr1016 is in production so really stuck with further testing - though might have to get one to open support tickets.
newly bought, had 6.3 on it I have just upgraded it to 6.10.
when i did a sniffer on the bond port I could see packets coming.
guess I can try again… pain to have to resetup again.
Just realized I don’t actually have serial cable ! …
Q)
I have moved it to balanced and turn the ports on switch to port-channel (not lacp).
Do I need to do that ?
I get the feeling I don’t
when i check my /interface print output there are 2 mac’s on the SPF+ interfaces, I thought it was meant to write the same on both !
checked it again with 6.10 and all is working well now !
with LACP that is
