Does anyone know if you can connect MikroTik to a LAG (Link Aggregation Group) configured set of switch ports?
example, I have a RB/1000 and want to connect 2 interfaces to a switch configured to bond 2 ports in one LAG for physical redundancy / additional capacity, and acheive a interface with 2Gbps of link capacity.
I know this could be done with bonding between 2 MikroTik’s, but how about at layer 2 for switch port compatibility between one MikroTik and a switch?
BTW, Dell defines a LAG as such:
The PowerConnect 2700 series switches support up to six aggregated links. Each of the
six aggregated links may be defined with up to four member ports to form a single Link Aggregated
Group (LAG).
The benefits of this facility are:
• Fault tolerance protection from physical link disruption
• Higher bandwidth connections
• Improved bandwidth granularity
• High bandwidth server connectivity
A LAG is composed of ports with the same speed set to full-duplex operation.
