LAN 2 LAN Wireguard tunnel
Hi all, i am struggling for the couple of days now trying to connect to of my routers via Wireguard tunnel and access my local LANs from either side.
The setup is as follows:
Router 1 ( my home)
Mikrotik hex switch latest 7.1.5 firmware
Internet > router > HAP Ac 2 wifi router
Router 2 ( my father’s house) Openwrt BT HUB 5A
fiber optik modem > router ( PPPoE connection) > LAN with some NVR and IP cameras.
My idea is to be able to access the lan from either side without any problems as they are in my local lan.
Here is the configuration of my Mikrotik router
# jan/02/2022 14:43:04 by RouterOS 7.1.5
# software id = 2Y0D-P7Z5
# model = RB750Gr3
# serial number =
add admin-mac=XXXXXXXXX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=XXXXXXXXX
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip ipsec proposal
set [ find default=yes ] disabled=yes enc-algorithms=3des
add name=dhcp ranges=192.168.88.30-192.168.88.80
add name=vpn-pool ranges=192.168.8.10-192.168.8.12
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/ppp profile
add dns-server=192.168.8.250 local-address=192.168.8.250 name=vpn-profile \
    remote-address=vpn-pool use-encryption=yes
/routing table
add fib name=""
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp,rest-api"
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
set discover-interface-list=all
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set authentication=mschap1,mschap2
/interface ovpn-server server
set auth=sha1 certificate=server-certificate cipher=aes128,aes192,aes256 \
    default-profile=vpn-profile require-client-certificate=yes
/interface wireguard peers
add allowed-address=192.168.9.4/32 comment=Phone interface=wireguard1 \
    public-key=""
add allowed-address=192.168.9.5/32 comment=MacBookAir interface=wireguard1 \
    public-key=""
add allowed-address=192.168.9.0/24,192.168.1.0/24 comment="Openwrt VPN" \
    endpoint-address=no-ip.com endpoint-port=51820 interface=wireguard1 \
    persistent-keepalive=25s public-key=\
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
add address=/24 interface=ether1 network=0
add address=192.168.9.2/24 interface=wireguard1 network=192.168.9.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.88.48 comment="NUC wifi" mac-address= \
    server=defconf
add address=192.168.88.49 comment="NUC cable" mac-address= \
    server=defconf
add address=192.168.88.43 comment="Raspberry pi 4" mac-address=\
     server=defconf
add address=192.168.88.52 client-id=1: mac-address=\
     server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.49 gateway=\
    192.168.88.1
set allow-remote-requests=yes servers=192.168.88.49
/ip dns static
add address=192.168.88.1 disabled=yes name=router.lan
add address=192.168.88.49 name="Home DNS"
add action=accept chain=input comment="Allow OpenVPN" dst-port= protocol=\
    tcp
    established,related,untracked
add action=accept chain=input comment="Wireguard VPN" dst-port=13231 \
    in-interface-list=WAN protocol=udp
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input port=1701,500,4500 protocol=udp
    invalid
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    in-interface-list=!LAN
add action=dst-nat chain=dstnat comment="OpenVPN Server NUC" disabled=yes \
    in-interface=ether1 log=yes log-prefix=VPN protocol=udp to-addresses=\
    192.168.88.49 to-ports=1122
add action=dst-nat chain=dstnat comment=Wireguard dst-port=52994 \
    in-interface=ether1 protocol=udp to-addresses=192.168.88.49 to-ports=\
    52994
add action=redirect chain=dstnat disabled=yes dst-port=53 protocol=tcp \
    src-port="" to-ports=53
add action=redirect chain=dstnat disabled=yes dst-port=53 protocol=udp \
    to-ports=53
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec policy
set 0 disabled=yes dst-address=0.0.0.0/0 src-address=0.0.0.0/0
add disabled=no dst-address=0.0.0.0/0 gateway=
add disabled=yes distance=1 dst-address=192.168.1.0/24 gateway=bridge \
    pref-src=192.168.1.1 routing-table=main scope=10 suppress-hw-offload=no \
    target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=192.168.9.0/32 \
    gateway=bridge pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ssh port=
/ppp secret
add name=sevim profile=vpn-profile
/system clock
set time-zone-name=Europe/
/system identity
set name=MikroTikRouter
/system ntp client
set enabled=yes
/system ntp client servers
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
And here is the Openwrt config:
config interface 'vpn'
	option proto 'wireguard'
	option private_key ''
	option listen_port '51820'
	list addresses '192.168.9.1/24'
	list addresses 'fdf1:e8a1:8d3f:9::1/64'
config wireguard_vpn
	option public_key ''
        option description 'Phone'
	option route_allowed_ips '1'
	list allowed_ips '192.168.9.20'
	option description 'mikrotik'
	option persistent_keepalive '25'
	option endpoint_port '13231'
	option endpoint_host 'home public IP'
	list allowed_ips '192.168.9.2'
	list allowed_ips '192.168.88.0/24'
	list allowed_ips '192.168.9.0/24'
	option description 'Macbook'
	list allowed_ips '192.168.9.21/24'
config route
	option target '192.168.9.1/24'
	option gateway '192.168.1.0/24'
	option netmask '192.168.9.0/24'
	option interface 'vpn'
(1) Is the initial connection established between the houses based on the Mikrotik being the Server ??? (not for the data flow which is two way, but for the connection piece, as it is for the mobile devices)
On the Mikrotik Peer Setting for OPENVPN Peer… ( also assume the subnet at your other house has a lan subnet of 192.168.1.0/24 )
add allowed-address=192.168.9.0/24,192.168.1.0/24 comment=“Openwrt VPN”
endpoint-address=no-ip.com endpoint-port=51820 interface=wireguard1 \ ???
persistent-keepalive=25s public-key=\ ???
this should be 192.168.9.1/32
(2) Where are all your forward chain firewall rules???
(3) Should be changed to bridge
192.168.88.0
(4) What is the purpose of this Route???
gateway=bridge pref-src=“” routing-table=main scope=30
You need route to remote subnet 192.168.1.0/24, which you have, but disabled and with wrong gateway, it should be one of:
add dst-address=192.168.1.0/24 gateway=wireguard1
add dst-address=192.168.1.0/24 gateway=192.168.9.1
And on the other side, I never tried WG with OpenWRT, but the last “config route” looks completely wrong, I’d say it shouldn’t be there.
@anav:
(1) Both sides have public addresses, so connection can be initiated from either side. As for allowed addresses, the day has come, young @anav, to reveal the last(?) secret to you, I didn’t tell you the whole truth before. In this case, 192.168.9.0/24 is not wrong, because WG’s cryptorouting works similar to regular routing, where broad route can be overriden by more specific one. So this allows e.g. Phone to have local .4 when connected to RB, but also to use remote .20 when connected to remote router.
(2) In export, it’s MikroTik’s default firewall, it blocks new connections from WAN and allows everything else.
(3) Yes (but it’s not breaking anything).
(4) To confuse enemies if they take over the router. :wink:
Oh I was not fussed about it, if it was clear that both side could BY design connect but I was still gathering requirements information before making any final assessments…
Any device used as a relay the .0 makes sense…
  1. yes the initial connection is established when i activate the tunnel, but can not ping anything from the LAN from either side
  2. I have no idea where, i am not a total noob but close to it :slight_smile:
  3. will change it and see what happens
  4. i thought that with this route i can give access to my local bridge LAN
The idea as i said im my first post is that when i am at home on my laptop when i type address from my father’s house i will be able to access it, for example if i want to see the feed from the NVR and IP cams, or a local home server that i am planning on installing, and vise versa.Like i have at my home a nextcloud server and if i want to show pictures to my family so i can do it without using WG on my phone or laptop.I do realize that probably it is not a safe practice to connect two networks like that all the time,thats why probably i will activate the tunnel only when i need it.
Thanks for ypur replies.
p.s
my openvpn server on the router is not in use, once the wg support was added to mikrotik i stopped using it.
p.s2
i posted the same question at Openwrt forum if anyone is interested in
https://forum.openwrt.org/t/lan-to-lan-wireguard-tunnel-over-the-internet/123818
I had to diagram this for myself to make heads or tails of it. Agreed with @sob here, I think the main problem is just a basic routing issue rather than anything wrong with your Wireguard configuration. To confirm, can your routers ping each other on the addresses (192.168.9.2 ↔ 192.168.9.1) you’ve assigned to the Wireguard link? That looks like it should be possible as it is currently configured and would confirm you can get packets across the tunnel.
Reference your diagram, can only speak to MT,
On the MT side of the house the IP address for the Wireguard interface ensures any ping traffic to the wireguard interface will be returned etc…
So the only route required is
add dst-address=192.168.1.0/24 gateway=wireguard1 table=main
However relooking at the config I found this puzzling rule…
52994
I cannot figure out its purpose???
Correct, maybe I should have been more clear that the red routes are present in the configs and should be removed and the green routes are their replacement.
Either address or wg interface name works, less typos if you uses the name I find.
This is my second WG server on my home NUC server , that i use as road warrior setup, the wg interface on the router has two purposes
1 to establish conn with other router
2 if anything happened to my home server and i can not access it, i have at least some access to my LAN through my router, i am traveling a lot so sometimes the wife and the little one are without internet so i have to figure out why,ISP or the little one pulled all the cords and cables from the wifi router, ask me how i know :slight_smile:
Why dont you wireguard into it vice port forward into it??
Seems like a very insecure method to me…
What do you mean? actually to use the WG on the home server instead?
UPDATE:
I have managed to make it work as intended thanks to all of you!!!
Please see below the latest configs from both sides MT and OpenWrt
MT:
# apr/05/2022 08:23:54 by RouterOS 7.1.5
# model = RB750Gr3
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge
/interface lte apn
/ip ipsec proposal
/port
set 0 name=serial0
/ppp profile
/routing table
add fib name=""
/user group
/ipv6 settings
    public-key=""
    public-key="="
add allowed-address=192.168.9.2/32,192.168.9.1/32,192.168.1.0/24 comment=\
    "Openwrt VPN" endpoint-port=51820 interface=wireguard1 \
    192.168.88.0
add address=public IP/24 interface=ether1 network=.0
/ip cloud
set update-time=no
/ip dhcp-client
add address=192.168.88.48 comment="NUC wifi" mac-address=:D6 \
    server=defconf
add address=192.168.88.49 comment="NUC cable" mac-address=:7F \
    server=defconf
    DC:A6:32:8B:BC:94 server=defconf
add address=192.168.88.52 client-id=:f6 mac-address=\
    B:F6 server=defconf
    192.168.88.1
/ip dns static
add action=accept chain=input comment="Allow OpenVPN" dst-port=1194 protocol=\
    tcp
add action=accept chain=forward comment="OpenWRT Wireguard" dst-address=\
    192.168.1.0/24 src-address=192.168.88.0/24
add action=accept chain=forward dst-address=192.168.88.0/24 src-address=\
    192.168.1.0/24
    invalid
    52994
    to-ports=53
/ip ipsec policy
add disabled=no dst-address=0.0.0.0/0 gateway=XX.XX.XX.1
add disabled=no dst-address=192.168.1.0/24 gateway=wireguard1 routing-table=\
    main suppress-hw-offload=no
/ip service
set ssh port=2
/ppp secret
/system clock
/system identity
/system ntp client
set enabled=yes
add
add
add
/tool mac-server
/tool sniffer
set filter-interface=wireguard1
OpenWrt
config interface 'loopback'
	option ifname 'lo'
	option proto 'static'
	option ipaddr '127.0.0.1'
	option netmask '255.0.0.0'
config globals 'globals'
	option ula_prefix 'fde5:fe4e:f4fe::/48'
config atm-bridge 'atm'
	option vpi '1'
	option vci '32'
	option encaps 'llc'
	option payload 'bridged'
	option nameprefix 'dsl'
config dsl 'dsl'
	option annex 'a'
	option tone 'av'
	option ds_snr_offset '0'
config interface 'lan'
	option type 'bridge'
	option ip6assign '60'
	option ifname 'eth0 eth0.1 vpn'
	list ipaddr '192.168.1.1/24'
config device 'lan_eth0_1_dev'
	option name 'eth0.1'
	option macaddr 'xx:xx:xx:xx:xx:xx'
config interface 'wan'
	option proto 'pppoe'
	option username 'user'
	option password 'pass'
	option ifname 'eth0.2'
	option macaddr ''
	option ipv6 '0'
	option delegate '0'
	option mtu '1500'
	option metric '1'
config device 'wan_dsl0_dev'
	option name 'dsl0'
	option macaddr 'xx.xx.xx.xx.xx'
config interface 'wan6'
	option ifname '@wan'
	option proto 'dhcpv6'
config switch
	option name 'switch0'
	option reset '1'
	option enable_vlan '1'
config switch_vlan
	option device 'switch0'
	option vlan '1'
	option ports '0 1 2 4 6t'
config switch_vlan
	option vlan '2'
	option ports '5 6t'
	option description 'phone'
	list allowed_ips '192.168.1.0/32'
	list allowed_ips '192.168.9.5'
	list allowed_ips '192.168.9.4'
Now I have to test if I have access to these subnets via my road warrior setup ( phone and laptop) if not try to make the adjustments, but even I don’t I will keep it like this, It took me a lot of time and other people time as well. Once again thank you very very much!
UPDATE #2
So the situation is as follows:
When i connect with my phone or laptop to my MT’s WG I:
  1. can ping 192.168.88.0 subnet
  2. can access 192.168.88.49 port 80 nextcloud
  3. can not access any other ports on the same IP (strange) i have a pi-hole running on port 8888, but no luck!
  4. can not access 192.168.88.1 via winbox or mikrotik android app, but can access the other wifi router on 192.168.88.2!?
  5. Can not ping any IP on 192.168.1.0 subnet
    When i connect with my phone to the other side to the Openwrt router’s WG:
  6. can not ping anything from 192.168.88.0 subnet
  7. have access to the router and the 192.168.1.0 subnet
I was thinking of client isolation? maybe this is the problem, what do you think?
UPDATE #3
Happy to report that the part of the problems in update #2 were actually my problem ( I doubt someone was thinking something else :smiley: ) and not a problem in the configuration. So the only thing to do was to look in my home server firewall and allow everything from Wireguard subnet, now I can access the home server (192.168.88.49) and all its services from 192.168.9.0 subnet.
Only thing to sort out is pinging 192.168.1.1 while connected directly to the MT router from my phone.
Latest UPDATE:
# 04/10/2022 08:59:44 by RouterOS 7.1.5
# model = RB750Gr3
# serial number =
/interface lte apn
/ip ipsec proposal
/port
set 0 name=serial0
/ppp profile
/routing table
add fib name=""
/user group
/ipv6 settings
    public-key=""
    public-key=""
add allowed-address=\
    192.168.9.2/32,192.168.88.0/24,192.168.1.0/24,192.168.9.0/24 comment=\
    "Openwrt VPN" endpoint-address=OPENWRT DDNS IP endpoint-port=51820 \
    interface=wireguard1 persistent-keepalive=25s public-key=\
    192.168.88.0
add address=public IP/24 interface=ether1 network=public IP mask
/ip cloud
set update-time=no
/ip dhcp-client
    server=defconf
    server=defconf
     server=defconf
add address=192.168.88.52 client-id= mac-address=\
     server=defconf
    192.168.88.1
/ip dns static
add action=accept chain=input comment="Allow OpenVPN" disabled=yes dst-port=\
    1194 protocol=tcp
add action=accept chain=input comment="Wireguard VPN NUC" dst-port=13231 \
add action=accept chain=input comment="Wireguard VPN" dst-address=\
    192.168.88.0/24 src-address=192.168.9.0/24
add action=accept chain=input comment="Wireguard VPN" disabled=yes \
    dst-address=192.168.9.0/24 in-interface=wireguard1 src-address=\
    192.168.1.0/24
    invalid
    52994
    to-ports=53
/ip ipsec policy
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=wireguard1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=yes distance=1 dst-address=192.168.88.0/24 gateway=wireguard1 \
    pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set ssh port=
/ppp secret
add name= profile=vpn-profile
/system clock
/system identity
/system ntp client
set enabled=yes
add
add
add
/tool mac-server
/tool sniffer
This solves all issues. Case closed Thanks again everyone!
