Sorry, 1xWAN, 4xLAN of course. I know, that it should work out of the box, but it doesent.
# feb/10/2020 16:18:51 by RouterOS 6.45.8
# software id = QCX6-3PXK
# model = RB750Gr3
# serial number = 8AFF0BFxxxx
/interface bridge add comment="ALL WAN INTERFACES" name=bridge0wan
/interface bridge add comment="ALL LAN INTERFACES" name=bridge1lan
/interface ethernet set [ find default-name=ether1 ] comment="WAN"
/interface ethernet set [ find default-name=ether2 ] comment="SWITCH "
/interface ethernet set [ find default-name=ether3 ] comment="AP UniFi"
/interface ethernet set [ find default-name=ether4 ] comment="QNAP LINK1"
/interface ethernet set [ find default-name=ether5 ] comment="QNAP LINK2" mac-address=C4:AD:xx:xx:xx
/interface bonding add down-delay=100ms lacp-rate=1sec mode=802.3ad name=qnap-bonding-e4-e5 slaves=ether4,ether5 up-delay=100ms
/interface ethernet switch port set 1 vlan-mode=disabled
/interface ethernet switch port set 2 vlan-mode=disabled
/interface ethernet switch port set 3 vlan-mode=disabled
/interface ethernet switch port set 4 vlan-mode=disabled
/interface ethernet switch port set 5 vlan-mode=disabled
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik
/ip hotspot profile set [ find default=yes ] html-directory=flash/hotspot
/ip ipsec peer add exchange-mode=ike2 name=peer1 passive=yes
/ip ipsec profile set [ find default=yes ] dh-group=ecp256,modp2048,modp1024 enc-algorithm=aes-256,aes-192,aes-128,3des
/ip pool add name="VPN POOL" ranges=192.168.30.100-192.168.30.150
/ip pool add name="LAN DHCP POOL" ranges=192.168.20.100-192.168.20.200
/ip dhcp-server add address-pool="LAN DHCP POOL" disabled=no interface=bridge1lan lease-time=1d name="LAN DHCP"
/ppp profile add change-tcp-mss=yes dns-server=xx.xx.xx.xx,1.1.1.1 local-address="VPN POOL" name=OFFICEPROFILE remote-address="VPN POOL" use-encryption=yes
/interface bridge port add bridge=bridge1lan interface=ether2
/interface bridge port add bridge=bridge0wan interface=ether1
/interface bridge port add bridge=bridge1lan interface=ether3
/interface bridge port add bridge=bridge1lan interface=qnap-bonding-e4-e5
/interface bridge settings set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/ip neighbor discovery-settings set discover-interface-list=LAN
/interface detect-internet set detect-interface-list=all
/interface l2tp-server server set authentication=mschap1,mschap2 default-profile=OFFICEPROFILE enabled=yes ipsec-secret=xxxxxxx! use-ipsec=yes
/interface list member add interface=bridge0wan list=WAN
/interface list member add interface=bridge1lan list=LAN
/ip address add address=xx.xx.xx.xx/30 comment="WAN NETWORK" interface=bridge0wan network=xx.xx.xx.xx
/ip address add address=192.168.20.254/24 comment="LAN NETWORK" interface=bridge1lan network=192.168.20.0
/ip address add address=10.125.24.1/24 interface=bridge1lan network=10.125.24.0
/ip dhcp-server network add address=192.168.20.0/24 gateway=192.168.20.254
/ip dns set servers=192.168.20.245,1.1.1.1
/ip dns static add address=192.168.88.1 name=router.lan
/ip firewall address-list add address=192.168.30.0/24 list=VPN-LOCAL
/ip firewall address-list add address=216.218.206.0/24 comment="VPN Shadowserver spam" list=BLACKLIST
/ip firewall address-list add address=xx.xx.xx.xx list=SAFESTAR
/ip firewall address-list add address=xx.xx.xx.xx list=WHITELIST
/ip firewall filter add action=drop chain=input src-address-list=BLACKLIST
/ip firewall filter add action=add-src-to-address-list address-list=BLACKLIST address-list-timeout=1h chain=input comment="Port Scanner Detect IP add to blacklist" protocol=tcp psd=21,3s,3,1 src-address-list=!WHITELIST
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=accept chain=input comment="WINBOX ACCESS FROM VPN" dst-port=8291,80,443,20022 protocol=tcp src-address-list=VPN-LOCAL
/ip firewall filter add action=accept chain=input comment="IPSec UDP Ports" dst-port=500,4500 protocol=udp
/ip firewall filter add action=accept chain=input comment="L2TP UDP Ports" dst-port=1701 protocol=udp
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid log-prefix=INV
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN log-prefix=IN
/ip firewall filter add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
/ip firewall filter add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat comment="WAN MASQUERADE" ipsec-policy=out,none out-interface-list=WAN
/ip firewall raw add action=drop chain=prerouting comment="block open DNS server" dst-port=53 in-interface-list=WAN protocol=udp
/ip firewall raw add action=drop chain=prerouting comment="block open DNS server" dst-port=53 in-interface-list=WAN protocol=tcp
/ip route add distance=1 gateway=xx.xx.xx.xx
/ip service set telnet disabled=yes
/ip service set ftp disabled=yes
/ip service set www disabled=yes
/ip service set ssh port=xxxx
/ip service set api disabled=yes
/ip service set api-ssl disabled=yes
/ppp aaa set use-radius=yes
/ppp secret add local-address=192.168.30.99 name=ss-backups password=xxxxxxxx profile=OFFICEPROFILE remote-address=192.168.30.100 service=l2tp
/radius add address=192.168.20.250 secret=xxxxxxxxx service=ppp,login,ipsec
/system clock set time-zone-name=Europe/Warsaw
/system identity set name=xxxxx
/system logging add prefix=RADIUS topics=radius
/system ntp client set enabled=yes primary-ntp=194.146.251.100 secondary-ntp=194.146.251.101
/system package update set channel=long-term
/tool bandwidth-server set enabled=no
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
/user aaa set use-radius=yes
Here is full drop of my config, i have to add this line, and now it works fine, but it consumes CPU
