Lan connection between 2 x RB433
Hi guys
I am quite a new Mikrotik user and have a stupid issue i cant get my head around.
Setup:
I have a RB433 with a configured lan ip on eth1. This is connected to my network switch.
I’m adding a RB433AH to my setup and its connected via eth1 to the RB433 on eth2.
All three eth connections have ip’s in the same range.
My problem:
I need to be able to access both the routerboards from my network but for some reason i’m not able to do so. I can access the RB433 without any problems but not the RB433AH.
Do i need so kind of static route to route traffic from the RB433 eth1, through eth2 onto the RB433AH eth1.
Sorry for this stupid question, i know this is a small issue, just cant seem to figure it out.
Regards
Greeny
if you want to route - you need different IP ranges. if you use the same range everywhere - use bridging
