LAN Connection Issues - no route to host
Hi All
I’d posted this in the wrong forum - Under Beginners Basics, just reposing to correct area.
This is my setup:
951Ui-2HnD running ros 6.41. I have an adsl modem connected to ether1 - thin would be the WAN. Wireless is set up, with the other ports on the switch all part of the Bridge/Lan
Having a battle with my network at the moment. I can ping from one device to another in the Bridge, but as soon as I try to run something, it says no route to host. I was testing with Netcat, listening on one device but getting the same issue, no route to host!
Herewith some configuration settings of the router:
[admin@MikroTik] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          10.0.0.2                  1
 1 ADC  10.0.0.0/24        10.0.0.101      ether1                    0
 2 ADC  192.168.88.0/24    192.168.88.1    bridge                    0
[admin@MikroTik] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     192.168.88.1/24    192.168.88.0    bridge
 1 D 10.0.0.101/24      10.0.0.0        ether1
 [admin@MikroTik] > ip firewall filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 2    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 3    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 4    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
 5    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
 6    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
 7    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related
 8    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
 9    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
10    ;;; defconf:  drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
[admin@MikroTik] > ip firewall nat print
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
[admin@MikroTik] > interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1598       2028 6C:3B:6B:A0:53:66
 1   S ether2                              ether            1500  1598       2028 6C:3B:6B:A0:53:67
 2   S ether3                              ether            1500  1598       2028 6C:3B:6B:A0:53:68
 3  RS ether4                              ether            1500  1598       2028 6C:3B:6B:A0:53:69
 4   S ether5                              ether            1500  1598       2028 6C:3B:6B:A0:53:6A
 5  RS wlan1                               wlan             1500  1600       2290 6C:3B:6B:A0:53:6B
 6  R  ;;; defconf
       bridge                              bridge           1500  1598            6C:3B:6B:A0:53:67
This is a strange one, and although not that well versed with RouterOs, the networking seems ok to me, unless I’m missing something obvious. It seems that RouterOs is trying to route packets that are in the LAN, all on the same bridge. This should not be happening in my understanding, as all traffic in the LAN/Bridge should be open??
Anyway, if anyone can help, much appreciated. Have Google’d and searched forums etc, but no joy.
Edit:
As a side note, I’m adding in my ping from one device to another. Surely this shouldn’t be s, high ms - as you can see the first two are really high in ms, and then seems to come down. Dunno if this is something on the router not going well?
ant@localhost ~/Downloads/Torrents % ping 192.168.88.253
PING 192.168.88.253 (192.168.88.253) 56(84) bytes of data.
64 bytes from 192.168.88.253: icmp_seq=1 ttl=64 time=2535 ms
64 bytes from 192.168.88.253: icmp_seq=2 ttl=64 time=1522 ms
64 bytes from 192.168.88.253: icmp_seq=3 ttl=64 time=498 ms
64 bytes from 192.168.88.253: icmp_seq=4 ttl=64 time=85.1 ms
64 bytes from 192.168.88.253: icmp_seq=5 ttl=64 time=309 ms
64 bytes from 192.168.88.253: icmp_seq=6 ttl=64 time=229 ms
64 bytes from 192.168.88.253: icmp_seq=7 ttl=64 time=4.20 ms
64 bytes from 192.168.88.253: icmp_seq=8 ttl=64 time=274 ms
64 bytes from 192.168.88.253: icmp_seq=9 ttl=64 time=297 ms
64 bytes from 192.168.88.253: icmp_seq=10 ttl=64 time=18.1 ms
64 bytes from 192.168.88.253: icmp_seq=11 ttl=64 time=42.3 ms
64 bytes from 192.168.88.253: icmp_seq=12 ttl=64 time=60.0 ms
64 bytes from 192.168.88.253: icmp_seq=13 ttl=64 time=228 ms
64 bytes from 192.168.88.253: icmp_seq=14 ttl=64 time=307 ms
Hi All
Error was my side. Checked on my on device - firewall shouldn’t have been on, but it was, hence I had the issues of not connecting.
:cry: :cry:
